[postgis-users] Error during the coordinate transformation
Eduin Carrillo
yecarrillo at gmail.com
Fri Mar 27 14:24:12 PDT 2009
Hola Fernando. Tu inquietud debe ser resuelta mas bien en la lista de
desarrollo del proyecto PROJ.4
(http://lists.maptools.org/mailman/listinfo/proj)
También puedes enviar el reporte del bug en http://trac.osgeo.org/proj/newticket
Hace unos años logré incluir los parámetros de transformación (7
parámetros) para los sistemas de referncia de Colombia, enviando el
reporte del Bug y sustentandolos con las definiciones de EPSG
(www.epsg-registry.org/)
Hi Fernando. This question is more related to PROJ.4 Library. Maybe
you can submit it to its mailing list or report it as bug.
A few years ago, I got some changes to the definition of the datums
for Colombia by adding the "towgs84" parameters. I just report that
bug and the EPGS registry link.
Eduin Yesid Carrillo Vega
Ingeniero Civil, Esp. Sistemas de Información Geográfica
Grupo IDE & GIG
Centro de Investigación y Desarrollo en Información Geográfica
Instituto Geográfico Agustín Codazzi - IGAC
Cr 30 48-51
Tel +57 1 3694000 ext 4305
Bogotá D.C., Colombia
2009/3/27 Fernando Javier Luyo Zegarra <fluyoz at hotmail.com>:
> Hello,
> I'm developed a routine for transforming coordinates of points which are in
> PSAD56 Zone 18S (srid = 24878) to Wgs84 Zone 18s (srid = 32718)
> The items are stored in the fields "geom" the table "MyTable" (srid =
> 24878).
> To perform the operation using the following syntax:
> select Transform (geom, 32718) from MyTable
> Reviewing the results found that there is an error:
> Example:
> Point in Psad56 Zn 18s
> X = 264365.2955 Y = 8665287.3660 Z = 0.0000
> The result of the transformation is:
> X = 264366.1196 Y = 8665292.17 Z = 0.0000
> However, the same point in cartografia WGS84 Zone 18S has the following
> coordinates:
> X = 264143.0640 Y = 8664919.0231 Z = 0.0000
> Apparently the SRID of the parameters are not properly used or applied
> incorrectly the function Transform ()
> While waiting for your help
> Fernando Luyo
> pd: Sorry for my bad English
> Hola
> Estoy elaborando una rutina para transformar coordenadas de puntos que estan
> en PSAD56 Zona 18S (srid=24878) a Wgs84 Zona 18s (srid=32718)
> Los puntos estan almacenados en el campo "geom" de la tabla "MyTable"
> (srid=24878).
> Para realizar la operacion estoy usando la siguiente sintaxis:
> select Transform(geom,32718) from MyTable
> Al revisar los resultados encontre que hay un error :
> Ejemplo :
> Punto en Psad56 Zn 18s
> El resultado de la transformacion es:
> Sin embargo, el mismo punto en cartografia en WGS84 Zona 18S tiene las
> siguientes coordenadas:
> Al parecer los parametros de los SRID usado no estan correctos o estoy
> aplicando mal la funcion Transform()
> A la espera de su ayuda
> saludos
> Fernando Luyo
> ________________________________
> Explore the seven wonders of the world Learn more!
> postgis-users mailing list
