[postgis-users] Determining geometry type from table
Marc Jansen
jansen.marc at gmx.de
Sat Mar 28 07:13:00 PDT 2009
Hey Robert,
I'm not sure if your question is still unanswered but you might have a
look at the table "geometry_columns". There should be an entry for your
spatially enabled table if the geometry was registered correctly.
Otherwise the function ST_GeometryType(your_geometry_field) should give
the needed information.
Bye,
Marc
Robert Hicks schrieb:
> Hello all, is there a way to determine the geometry of a table in
> Postgres 8.2/Postgis? I want to execute a sql query against a table
> and get back POLYGON, LINE, etc. and I am guessing there is a stored
> procedure for this.
> Thanks!
> postgis-users mailing list
