[postgis-users] Insert record using SRID
Paul Ramsey
pramsey at opengeo.org
Thu May 7 08:34:21 PDT 2009
INSERT INTO spl_points (the_geom)
VALUES ( ST_GeomFromText('POINT(115.64 -33.34)', 4326) );
On Thu, May 7, 2009 at 8:24 AM, benton101 <Ben.Davies at dec.wa.gov.au> wrote:
> Hi,
> I want to insert a record into a table with a specific SRID. The SRID value
> I want to use is 4283 which should be Geographic Coordinates. I then want to
> use ST_Transform to change the SRID to 28350 which should be Map Grid
> Australia coordinates. I have posted a message with reference to a
> ST_Transform problem I am having which I have'nt resolved yet and so in an
> attempt to resolve that question I thought I would create a test for what I
> am inserting, but now I have run into more problems. This is what I have
> done to insert a record in Geographic Coords ...
> DROP TABLE spl_points;
> CREATE TABLE spl_points
> gid serial NOT NULL
> WITH (OIDS=FALSE);
> ALTER TABLE spl_points OWNER TO postgres;
> ALTER TABLE "spl_points" ADD CONSTRAINT spl_points_pkey PRIMARY KEY (gid);
> -- Add geometry column
> SELECT AddGeometryColumn('','spl_points','the_geom','4283','POINT',2);
> INSERT INTO spl_points (the_geom)VALUES ( 'POINT(115.64 -33.34)');
> But this returns the following error ...
> ERROR: new row for relation "spl_points" violates check constraint
> "enforce_srid_the_geom"
> I don't know why this wont work when I change the value from 4283 to -1 it
> takes the record no problems but as far as I understand this is no use for
> me when I want to transform the record.
> Ben
> View this message in context: http://www.nabble.com/Insert-record-using-SRID-tp23428534p23428534.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
