[postgis-users] OIDS, PostGIS and Quantum GIS
Ben Madin ben at remoteinformation.com.au
Fri May 8 05:23:09 PDT 2009
Juan,
Agreed that this can be annoying (especially in light of some other
GIS packages which don't seem to care at all, or for instance
shapefiles.
I have had the same frustration when constructing geometries in a
query or for a view, or any type of aggregate query really. This is
also a problem for querymaps in MapServer.
The alternative I settled with was creating a false key - for instance
if the view was a makeline from points, making an id that was the gid
of the first * 100000 + the gid of the second.
That may help. It may not - but there are better minds than mine
hovering nearby, so I look forward to their suggestions.
cheers
Ben
On 08/05/2009, at 7:36 PM, Andreas Neumann wrote:
> hm - what's wrong with having a primary key in every table? Good DB-
> Design
> requires primary keys. Other tools will refuse to work with your
> data if
> you don't use primary keys as well. As an example, pgadmin3 requires a
> primary key if you want to edit the data in the grid view.
> If you use the datatype "serial" or a sequence it is not complicated
> at
> all to use primary keys.
> Andreas
> On Fri, May 8, 2009 1:18 pm, Juan Pedro Pérez Alcántara wrote:
>> Hello,
>> perhaps this is a silly one, but I'm having a hard time dealing with
>> primary keys restrictions in Quantum GIS. Not always is possible or
>> desirable to put a, sometimes, artificial int4 PK in some tables
>> only to
>> be able to load them in QGIS. Those restrictions are very
>> frustrating.
>> I have been messing around for a solution, and I have experimented
>> with
>> OIDS. This seems to be enough for QGIS, but I fear the behavior of
>> OIDS.
>> I don't like the idea of non-controlled PK in my tables. So my
>> question
>> is simple: does creating a table WITH OIDS means that the OIDS will
>> be
>> part of the PK of the table like you it or not, or you have to
>> specify
>> that the OIDS are part of the PK in the ADD CONSTRAINT statement?
>> My hope is that PostgreSQL uses internally OIDS without interfering
>> with
>> the true PK of the table, while QGIS is happy by having them around.
>> OIDS will not play any role in my model other than that.
>> Greetings,
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
