[postgis-users] OIDS, PostGIS and Quantum GIS
nicklas.aven at jordogskog.no
Fri May 8 05:45:57 PDT 2009
as said earlier it's really not that hard to add a colunm with the datatype serial wich means it will get a unique new value as default.
And if you have a textbased primary key or any other reason for not wanting to cunstruct a new primary key qgis will be satisfied with a unique value. So just do
alter table theTable add column uniqueID serial UNIQUE ;
then you acn add and remove records without caring about your unique value-field
Hope that helps
Nicklas
2009-05-08 Ben Madin wrote:
Juan,
>Agreed that this can be annoying (especially in light of some other
>GIS packages which don't seem to care at all, or for instance
>shapefiles.
>I have had the same frustration when constructing geometries in a
>query or for a view, or any type of aggregate query really. This is
>also a problem for querymaps in MapServer.
>The alternative I settled with was creating a false key - for instance
>if the view was a makeline from points, making an id that was the gid
>of the first * 100000 + the gid of the second.
>That may help. It may not - but there are better minds than mine
>hovering nearby, so I look forward to their suggestions.
>cheers
>Ben
>On 08/05/2009, at 7:36 PM, Andreas Neumann wrote:
>> hm - what's wrong with having a primary key in every table? Good DB-
>> Design
>> requires primary keys. Other tools will refuse to work with your
>> data if
>> you don't use primary keys as well. As an example, pgadmin3 requires a
>> primary key if you want to edit the data in the grid view.
>> If you use the datatype "serial" or a sequence it is not complicated
>> at
>> all to use primary keys.
>> Andreas
>> On Fri, May 8, 2009 1:18 pm, Juan Pedro Pérez Alcántara wrote:
>>> Hello,
>>> perhaps this is a silly one, but I'm having a hard time dealing with
>>> primary keys restrictions in Quantum GIS. Not always is possible or
>>> desirable to put a, sometimes, artificial int4 PK in some tables
>>> only to
>>> be able to load them in QGIS. Those restrictions are very
>>> frustrating.
>>> I have been messing around for a solution, and I have experimented
>>> with
>>> OIDS. This seems to be enough for QGIS, but I fear the behavior of
>>> OIDS.
>>> I don't like the idea of non-controlled PK in my tables. So my
>>> question
>>> is simple: does creating a table WITH OIDS means that the OIDS will
>>> be
>>> part of the PK of the table like you it or not, or you have to
>>> specify
>>> that the OIDS are part of the PK in the ADD CONSTRAINT statement?
>>> My hope is that PostgreSQL uses internally OIDS without interfering
>>> with
>>> the true PK of the table, while QGIS is happy by having them around.
>>> OIDS will not play any role in my model other than that.
>>> Greetings,
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Andreas Neumann
>> http://www.carto.net/neumann/
>> http://www.svgopen.org/
>Ben Madin
>REMOTE INFORMATION
>t : +61 8 9192 5455
>f : +61 8 9192 5535
>m : 0448 887 220
>Broome WA 6725
>ben at remoteinformation.com.au
> Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090508/f2f3d5ef/attachment.html>
