[postgis-users] spatial_ref_sys
Obe, Regina
robe.dnd at cityofboston.gov
Wed May 13 08:02:35 PDT 2009
Genis,
http://www.spatialreference.org/ref/epsg/23031/
use the PostGIS isnert statement. i susually change the srid to match the EPSG.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Genís Pujol Hamelink
Sent: Wednesday, May 13, 2009 10:44 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] spatial_ref_sys
Hello list,
In the postgis datatable there is an entry for the ED50 / 30N but not for ED50 / 31N and I need to add this into the db:
PROJCS["ED_1950_UTM_Zone_31N",
GEOGCS["GCS_European_1950",
DATUM["European_Datum_1950",
SPHEROID["International_1924",
6378388.0,297.0]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",3.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
I miss the info regarding the EPSG or the auth codes and I'm not sure if I can add it as a custom dataset and make up those codes without braking anything...
How can I add this into the db without braking anything? sorry I'm a noob at gis... :)
regards,
Genis
Genís
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090513/8aef0e20/attachment.html>
