[postgis-users] How to generate a bounding box using postgis java classes ?
Smith Roman autisi at yahoo.com
Sat May 16 08:00:07 PDT 2009
How can I use the java classes in the postgis driver to generate a bounding box that encloses a set of points. Each point represented as a pair of java double data types ? Or do I have to use the JTS api ?
Thanks,
Smith.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090516/20a760ed/attachment.html>
