[postgis-users] upgrade problem
Gavin Fleming GavinF at mintek.co.za
Tue May 19 06:05:20 PDT 2009
I'm stuck, my PostGIS is broken...
I was successfully running PostGreSQL8.2 with PostGIS 1.2 on Ubuntu
7.10.
I recently upgraded Ubuntu to 8.04 LTS, including doing apt-get
dist-upgrade after the upgrade.
SELECT postgis_version() and any other command that invokes PostGIS now
gives this:
ERROR:  could not access file
"/usr/lib/postgresql/8.2/lib/liblwgeom.so.1.2": No such file or
directory
SELECT version() gives: "PostgreSQL 8.2.9 on i486-pc-linux-gnu, compiled
by GCC cc (GCC) 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2)"
Yet pg_config -version gives PostGreSQL 8.3.7
It seems PostGIS 1.3 has been installed and 1.2 removed.
I have a pg_dumpall backup but no individual DB backups with -Fc.
Any tips would be most appreciated as I'm not sure where to go next.
thanks
Gavin Fleming
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090519/18012a70/attachment.html>
