[postgis-users] Problems compiling PostGIS on Solaris 2.10/SparcV9
Alexander Von Luenen Alex.von-Luenen at port.ac.uk
Tue May 19 09:24:19 PDT 2009
I am trying to compile PostGIS on a SUN T5440 running Solaris 2.10, using gcc3.4.3. I have PostgreSQL 8.3.1 installed from the CSW repository, which has both 32bit and 64bit versions installed. Although the pg_config installed in /opt/csw/postgresql/bin is a 32bit binary (as I could check with 'file'), all paths etc. it returns are to the 64bit version of PostgreSQL. As I have compiled all libraries (GEOS, PROJ4, etc) as 32bit, this results in a linker error when compiling PostGIS, since it attempts to link the 32bit libs to the 64bit PostgreSQL libs. Using '-m32' as CPPFLAGS/CXXFLAGS didn't help. There is also a pg_config32 in the same directory as pg_config. How can I force configure to use this one? '--with-pgconfig' didn't work. The only solution I could think of is deleting/renaming pg_config, and setting a softlink to pg_config32. Any suggestions anybody?
Cheers,
Alex
Dr Alexander von Luenen
Senior Research Associate
Great Britain Historical GIS
Dept. of Geography
University of Portsmouth
Buckingham Building, Lion Terrace
Portsmouth, PO1 3HE, UK
tel: +44-(0)23-9284-2500
fax: +44-(0)23-9284-2512
