[postgis-users] more centos install troubles
Steve henshaw steve.henshaw at gmail.com
Tue May 19 16:18:33 PDT 2009
Hi Paul,
I was wondering if you were installing from the Centos repos?  I run
centos 5.3 with postgis myself and found it much easier using the
postgresql yum repo, details here:
http://yum.pgsqlrpms.org/
than using the centos repos which are also a bit out of date.
Hope that helps,
Steve
Paul McCullough wrote:
> All,
> When I do this
>> yum install postgresql-devel
> I get these errors
> --> Finished Dependency Resolution
> postgresql-devel-8.1.11-1.el5_1.1.x86_64 from base has depsolving problems
>   --> Missing Dependency: libpgtypes.so.2()(64bit) is needed by package
> postgresql-devel-8.1.11-1.el5_1.1.x86_64 (base)
>   --> Missing Dependency: libecpg_compat.so.2()(64bit) is needed by package
>   --> Missing Dependency: libpq.so.4()(64bit) is needed by package
> postgresql-devel-8.1.11-1.el5_1.1.i386 from base has depsolving problems
>   --> Missing Dependency: postgresql = 8.1.11-1.el5_1.1 is needed by package
> postgresql-devel-8.1.11-1.el5_1.1.i386 (base)
>   --> Missing Dependency: libecpg.so.5()(64bit) is needed by package
> Error: Missing Dependency: libecpg.so.5()(64bit) is needed by package
> Error: Missing Dependency: libpq.so.4()(64bit) is needed by package
> Error: Missing Dependency: libecpg_compat.so.2()(64bit) is needed by package
> Error: Missing Dependency: postgresql = 8.1.11-1.el5_1.1 is needed by
> package postgresql-devel-8.1.11-1.el5_1.1.i386 (base)
> Error: Missing Dependency: libpgtypes.so.2()(64bit) is needed by package
> package postgresql-devel-8.1.11-1.el5_1.1.x86_64 (base)
> [maddev:main.mad_db postgis-1.3.6]#
> I a few other paths including
>> yum install postgresql-devel.i386
>> yum install postgresql-devel.x86_64
>> yum install postgresql-contrib.x86_64
> with more or less the same results
> My system:
>> cat /etc/redhat-release
> CentOS release 5.3 (Final)
>> uname -a
> Linux mad_db 2.6.18.8-xenU #1 SMP Mon Aug 18 14:00:41 PDT 2008 x86_64 x86_64
> x86_64 GNU/Linux
> Without postgresql-devel I can't do this
>> ./configure --with-pgsql=/usr/bin/pg_config
>> --with-geos=/usr/local/bin/geos-config --with-proj=/usr/local
> Thanks!
> Paul
