[postgis-users] Newbie GIS/PostGIS Pointers
dustinb
dustin at intrcomm.net
Tue May 19 19:17:14 PDT 2009
I'm researching for an application which needs to store "zones" based on gps
points. Not sure the shape of these yet, most likely a circle or polygon.
The system then needs to determine what zone a particular "location" (gps
point) is in.
Can someone give me some direction as far as what terminology I should be
learning and using, good beginner tutorials, and/or documentation a ogc/gis
newbie should start with?
In what I've got out of it so far I'll need to create polygons (or other
geometry) and use st_within function do determine if the point is in that
geometry. What I don't understand yet is how these polygons get created
from lat/long data points.
Thanks!
Dustin
View this message in context: http://www.nabble.com/Newbie-GIS-PostGIS-Pointers-tp23627856p23627856.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
