[postgis-users] brake MPolygon to polygons
Marko Čubranić
mcubranic at gmail.com
Mon Feb 1 01:15:47 PST 2010
thanks Nicklas,
2010/2/1 Nicklas Avén <nicklas.aven at jordogskog.no>
> Hallo
> If I understand you right you have multipolygons representing countries
> that you want splitted to single polygons.
> That is no problem but they will not fit in the same table since you will
> get additional rows.
> If you want to make a new table with this country polygons as single
> polygons you can do
> create table single_polygon_countries as
> select (ST_Dump(the_geom)).geom as the_geom, countryID from
> original_country_table;
> I put countryID there, just to illustrate that you probably want to bring
> some id or name to the new table. That will be repeated for all single
> polygons from original multi polygon
> Hope that helps
> Nicklas
> 2010-02-01 Marko Èubraniæ wrote:
> Dear colleagues,
> >if i have x Mpolygons in table (country) and i want to brake each of them
> in polygons, and put polygons in new columns, how should i do that?..
> >thank you
> >Marko Cubranic
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100201/cd1671cf/attachment.html>
