[postgis-users] Split a polygon to N linestrings (Solved)
Nicolas Gillet - MARKET-IP
nicolas.gillet at market-ip.com
Mon Feb 1 23:56:13 PST 2010
Hello Kevin,
Thank you a lot for this perfectly clear query !
Nicolas
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] De la part de Kevin
Neufeld
Envoyé : vendredi 29 janvier 2010 17:44
À : PostGIS Users Discussion
Objet : Re: [postgis-users] Split a polygon to N linestrings
CREATE TEMP TABLE mypolygontable AS
SELECT
'MULTIPOLYGON(((0 0, 0 4, 4 4, 4 0, 0 0),
(1 1, 1 2, 2 2, 2 1, 1 1)),
((5 5, 5 6, 6 6, 6 5, 5 5))
)'::geometry geom;
-- make line segments from every startpoint and endpoint
SELECT ST_AsText( ST_MakeLine(sp,ep) )
FROM
-- extract the endpoints for every 2-point line segment for each
linestring
(SELECT
ST_PointN(geom, generate_series(1, ST_NPoints(geom)-1)) as sp,
ST_PointN(geom, generate_series(2, ST_NPoints(geom) )) as ep
FROM
-- extract the individual linestrings
(SELECT (ST_Dump(ST_Boundary(geom))).geom
FROM mypolygontable
) AS linestrings
) AS segments;
st_astext
LINESTRING(0 0,0 4)
LINESTRING(0 4,4 4)
LINESTRING(4 4,4 0)
LINESTRING(4 0,0 0)
LINESTRING(1 1,1 2)
LINESTRING(1 2,2 2)
LINESTRING(2 2,2 1)
LINESTRING(2 1,1 1)
LINESTRING(5 5,5 6)
LINESTRING(5 6,6 6)
LINESTRING(6 6,6 5)
LINESTRING(6 5,5 5)
(12 rows)
Cheers,
Kevin
On 1/29/2010 5:16 AM, Nicolas Gillet - MARKET-IP wrote:
> Hello,
> I am looking for some tips to split a polygon to its simplest linestrings.
> An example worth better than words :
> POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))
> Would become :
> MULTINLINESTRING((0 0, 0 1), (0 1, 1 1), (1 1, 1 0), (1 0, 0 0))
> Every single linestring has to have two and only two points.
> Is there a way to do this with the existing postgis functions ?
> I found several ways to turn a polygon to a (multi)linestring but not to
> split it then into shortest linestrings.
> Thanks for any input.
> Nicolas
> Gillet
> postgis-users mailing list
