[postgis-users] NOTICE: IllegalArgumentException: point array must contain 0 or >1 elements, ERROR: Exception in LWGEOM2GEOS
Martin Davis mbdavis at refractions.net
Thu Feb 4 09:24:24 PST 2010
This error is due to a design choice in JTS/GEOS, which reflected the
OGC SFS spec - LineStrings are not allowed to have a single point.
For users who use JTS and GEOS directly, this isn't as much of an issue,
because their language environments allow them to catch exceptions
easily.  But in PostGIS it might be better to trap this condition in the
isvalid code and return an appropriate result (false).
Daniel Degasperi wrote:
> |*Hi,
> I have some problems with a MultiLinestring imported with *||*shp2pgsql.
> If I try to check it's validity (or try to do anything else on it)*||*:
> SELECT
> isvalid('0105000020E0670000010000000102000020E06700000100000016DA52BA62A04141FFF3AD290B735241');
> *||*I get the Exception in my e-mail subject.
> How can I check the geometry, if already isvalid chokes. I could only
> select NumPoints(the_geom) and compare it to the allowed range of the
> geometry type (e.g. 0 or > 1 for MULTILINESTRINGS).
> Can this be considered to be a bug of PostGIS/GEOS?
> Software stack:
> CentOS 5.4, 64 bit
> PostgreSQL 8.2.14 (from CentOS Testing)
> PostGIS 1.4.1
> GEOS: 3.1.1
> *||*Best regards
> Daniel
>   Daniel Degasperi
>   Software Developer
>   daniel.degasperi at r3-gis.com
>   R3 GIS Srl
>   Via Johann Kravogl 2
>   I-39010 Merano - Sinigo (BZ)
>   Tel. +39 0473 494949
>   Fax. +39 0473 069902
>   Web  http://www.r3-gis.com
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
