[postgis-users] NOTICE: IllegalArgumentException: point array must contain 0 or >1 elements, ERROR: Exception in LWGEOM2GEOS
Daniel Degasperi
daniel.degasperi at r3-gis.com
Thu Feb 4 09:32:56 PST 2010
Hi Martin,
I like the proposed solution, should I create a ticket for this?
Am 04.02.2010 18:24, schrieb Martin Davis:
> This error is due to a design choice in JTS/GEOS, which reflected the
> OGC SFS spec - LineStrings are not allowed to have a single point.
> For users who use JTS and GEOS directly, this isn't as much of an
> issue, because their language environments allow them to catch
> exceptions easily. But in PostGIS it might be better to trap this
> condition in the isvalid code and return an appropriate result (false).
> Daniel Degasperi wrote:
>> |*Hi,
>> I have some problems with a MultiLinestring imported with *||*shp2pgsql.
>> If I try to check it's validity (or try to do anything else on it)*||*:
>> SELECT
>> isvalid('0105000020E0670000010000000102000020E06700000100000016DA52BA62A04141FFF3AD290B735241');
>> *||*I get the Exception in my e-mail subject.
>> How can I check the geometry, if already isvalid chokes. I could only
>> select NumPoints(the_geom) and compare it to the allowed range of the
>> geometry type (e.g. 0 or > 1 for MULTILINESTRINGS).
>> Can this be considered to be a bug of PostGIS/GEOS?
>> Software stack:
>> CentOS 5.4, 64 bit
>> PostgreSQL 8.2.14 (from CentOS Testing)
>> PostGIS 1.4.1
>> GEOS: 3.1.1
>> *||*Best regards
>> Daniel
>> Daniel Degasperi
>> Software Developer
>> R3 GIS Srl
>> Via Johann Kravogl 2
>> I-39010 Merano - Sinigo (BZ)
>> Tel. +39 0473 494949
>> Fax. +39 0473 069902
>> Web http://www.r3-gis.com
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Daniel Degasperi
Software Developer
R3 GIS Srl
