[postgis-users] postgis upgrade 1.4 to 1.5 sql file couldn't find $libdir/postgis-1.4
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Feb 24 02:04:17 PST 2010
Bruno Friedmann wrote:
> Doesn't know if already reported or what I'm doing wrong.
> In rpm (suppose to be the same with .deb) if you upgrade postgis from 1.4 to 1.5 the postgis-1.4 referenced in function doesn't
> exist after upgrade.
> As the default postgis upgrade script call the
> select postgis_lib_version();
> we get a fatal error
> ERROR: could not access file "$libdir/postgis-1.4": No such file or directory
> and all the process fail leaving normal user in trouble ...
> I've try to bypass it commenting the SELECT postgis_major_version_check();
> and get the sql executed ...
> Any comments ?
Hi Bruno,
Sorry but I'm not really sure what's happening here - I know that people
have tested the upgrade script when upgrading from 1.4 to 1.5 before the
final release and reported that it works.
I suspect you will need to talk to the maintainer of the .deb packages
you are using to find out why this is failing.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
