[postgis-users] Problems compiling Postgis from source in Ubuntu 9.10
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Jan 7 03:59:16 PST 2010
Roger André wrote:
> Hi Mark,
> I see from the Changelog that you committed many of the pgxs updates, so
> thanks for the response. A couple points I'd like to clarify.
> 1. I have not installed ANY Postgresql code from aptitude, nor do I wish
> to. Everything is fresh source code installed under /usr/local, and I
> would very much like to keep it that way. You're right that there is
> another pg_config in /usr/bin/pg_config though, but I have no idea how
> it got there. It's also strange that when I go through the locations
> specified by /usr/bin/pg_config, only some of them exist. Looks like
> some sort of partial install, or something. aptitude also has no record
> of installing any postgres* package, so not sure how it got there.
> 2. Totally willing to grant you that my configure options might be
> incorrect for PostGIS 1.4. I didn't realize they had changed from 1.3 to
> 1.4. I'll have a closer look at the ./configure --help output to make
> sure I specify them correctly. Would help if I pointed to the right
> pg_config. ;)
> 3. I am going to clean out all traces of the Ubuntu package on the
> system, and then will see if I can get the source to compile properly.
> Thanks again,
> Roger
Hi Roger,
I think it's related to the fact that multiple packages in Debian
install pg_config but not necessarily with the correct Makefile. I have
a feeling it is related to the libpq-dev package but it's quite
difficult to test unless you reinstall a machine from scratch :(
Glad that you managed to get it all installed though.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
