[postgis-users] Problems compiling Postgis from source in Ubuntu 9.10
Dave Potts dave.potts at pinan.co.uk
Thu Jan 7 04:03:39 PST 2010
Mark Cave-Ayland wrote:
Has anybody read this web page ?
http://workingonnothing.blogspot.com/2009/08/setting-up-ubuntu-server-installig.html
Its somebodies successful attempt to install postgis 1-4.0 using the
installed version of 8.3 on ubuntu Jaunty
Dave.
> Roger André wrote:
>> Hi Mark,
>> I see from the Changelog that you committed many of the pgxs updates,
>> so thanks for the response.  A couple points I'd like to clarify.
>> 1. I have not installed ANY Postgresql code from aptitude, nor do I
>> wish to.  Everything is fresh source code installed under /usr/local,
>> and I would very much like to keep it that way.  You're right that
>> there is another pg_config in /usr/bin/pg_config though, but I have
>> no idea how it got there.  It's also strange that when I go through
>> the locations specified by /usr/bin/pg_config, only some of them
>> exist.  Looks like some sort of partial install, or something.
>> aptitude also has no record of installing any postgres* package, so
>> not sure how it got there.
>> 2. Totally willing to grant you that my configure options might be
>> incorrect for PostGIS 1.4. I didn't realize they had changed from 1.3
>> to 1.4.  I'll have a closer look at the ./configure --help output to
>> make sure I specify them correctly.   Would help if I pointed to the
>> right pg_config. ;)
>> 3. I am going to clean out all traces of the Ubuntu package on the
>> system, and then will see if I can get the source to compile properly.
>> Thanks again,
>> Roger
> Hi Roger,
> I think it's related to the fact that multiple packages in Debian
> install pg_config but not necessarily with the correct Makefile. I
> have a feeling it is related to the libpq-dev package but it's quite
> difficult to test unless you reinstall a machine from scratch :(
> Glad that you managed to get it all installed though.
> ATB,
> Mark.
