[postgis-users] Job position in Italy for Python/PostGIS/XML/WebService researcher
Jorge de Jesus
jorge.de-jesus at jrc.ec.europa.eu
Thu Jul 1 06:10:49 PDT 2010
The Global Environment Monitoring Unit (Ispra, Italy) of the Joint
Research Centre of the European Commission is looking for a software
developer who will work on web processing services (WPS) for modelling
habitats in protected areas and on the uncertainty propagation between
web modeling services.
The ideal candidate has a PhD in geoinformatics (or a university degree
in a related field) _or_ at least 5 years research experience after the
university degree.
The candidate must have excellent skills in setting up OGC standard web
services using open source tools and a demonstrated experience in
geoinformatics and in setting up web mapping services.
Most developments will be made using Python, XML, PostGIS, QGIS and any
experience with these languages and tools would be an advantage.
Experience in setting up modeling services would be a strong asset.
A good knowledge of English is required. Good communication and
inter-personal skills and ability to work in a team are required. * *
*Information on how to apply can be found at
*http://ies.jrc.ec.europa.eu/Job-opportunities/open-calls/call-for-grantholders.html
The position falls in the category 30 (post-doc researchers)
*Job reference:* /IES-2010-301017/ (note that the announcement on the
web indicates a minimum experience of at least 4 years after university
degree while a PhD _or_ a strict minimum of 5 years is actually required)
*Deadline for application: *23^rd of July 2010
Should you have questions regarding the work to be done, please get in
touch with me.
Best regards
Gregoire
Grégoire Dubois (Ph.D.)
DG Joint Research Centre - European Commission
Monitoring Of Natural resources for DEvelopment (MONDE)
Via Fermi 2749, TP 440, I-21027 Ispra (VA), ITALY
Jorge Samuel Mendes de Jesus (PhD)
Institute for Environment and Sustainability (IES)
Global Environment Monitoring Unit (GEM)
MOnitoring Of Natural resources for DEvelopment (MONDE)
http://gem.jrc.ec.europa.eu
Tel : +39 0332 783536
Fax : +39 0332 789960
Email: jorge.de-jesus at jrc.ec.europa.eu
jorge.jesus at gmail.com
OpenPGPKey: 0xE915CB1E
"The views expressed are purely those of the writer and may not in any
circumstances be regarded as stating an official position of the European
Commission." (Disclaimer required under the terms and conditions of use of
the internet and electronic mail from Commission equipment)"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100701/2d38e78b/attachment.html>
