[postgis-users] PostGIS topology use ?
Andrea Peri
aperi2007 at gmail.com
Thu Jul 1 11:00:39 PDT 2010
>The idea behind topology is the if you have two polygons with a common
>edge, the the common edge is only represented as "one edge" and both
>polygons share that edge. if you make changes to that edge, then the
>polygons both have the same edge so it is not possible to create a gap
>between the two polygons.
Ok, I understand your point of view.
But I think a gap is always possible to create.
Certainly not moving some edges (editing the polygon), but , for
example, subtracting
a polygon from other two polygon and using a substracting polygon
intersect both the polygons.
This don't mean that a topology model will denied this subtracting.
It allow this subtracting , the subtracting will create a hole between
both the polygon (a gap) and the hole will be filled with a special
polygon called
"universe" that is empty on all the attributes.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100701/87ed9504/attachment.html>
