[postgis-users] Invalid geometry when using select AsText
Nicolas Ribot nicolas.ribot at gmail.com
Tue Jul 6 02:55:15 PDT 2010
> I am doing a GIS project where I combine shapefiles from different sources,
> created with different spatial reference systems.
> What I want to achieve is that if someone has a shapefile, no matter what
> the srs is, the data can be combined with other data. All data will be
> tranformed to srid 900913.
> I succeeded in combining data from my Dutch and Belgian colleagues by using
> the postgis transform function and transforming the geometries from "28992"(
> Amersfoort / RD New) and "31370"(Belge 1972 / Belgian Lambert 72) to 900913.
> This works perfeclty, the map of the Netherlands and Belgium are displayed
> as they should.
> My problem is the following. I also have some data from my colleagues from
> Spain. Their data supposedly is in "WGS1984" epsg "4326". So I transformed
> it to 900913 as I did with my other data. So far so good. BUT when I do a
> SELECT AsText from one of the geometries I get the following:
> "MULTIPOLYGON(((inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf
> inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,
> ...etc etc ... inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf inf,inf
> inf,inf inf,inf inf),(inf inf,inf inf,inf inf,inf inf,inf inf)))"
> I think this means that the geometry is invalid. When I read it from my
> application using Hibernate spatial I get an error like invalid geometry.
> I tried transforming from 4326 to 900913 and also from 94326 to 900913 but
> with no luck.
> Has anyone ever got this problem or does anyone knows what is going on here?
> Thank you,
> Ramses
What the spain data look like ? Could you post some extract of it (astext) ?
It seems the data range is not compatible with WGS84, thus generating
invalid coordinates when transformed.
Nicolas
