[postgis-users] WKT raster installation on mac
Paragon Corporation lr at pcorp.us
Wed Jul 7 14:38:15 PDT 2010
Shaun,
Sorry don't know much about Mac.
Do you have the postgresql develop contrib installed.  I think a lot of
those kind of errors happen if you don't have that installed.
Normally I compile postgis from scratch which does require the develop
contrib to be installed before you can.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Shaun
Langley
Sent: Wednesday, July 07, 2010 12:09 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] WKT raster installation on mac
I'm still getting stuck with this installation.  I specified the libdir, but
note that libpq is not in this directory.  The path for libpq is
"/Library/PostgreSQL/8.4/include" which is distinct from the other code
libraries in "/Library/PostgreSQL/8.4/lib"  I'm copying the directory
contents so you can clearly see what's included in each.
configure: error: could not find libpq
user-d0c71a:wktraster-0.1.6d langleys$ cd ../include/ user-d0c71a:include
langleys$ ls
ecpg_config.h		pg_config.h		pgtypes_numeric.h
ecpg_informix.h		pg_config_i386.h	pgtypes_timestamp.h
ecpgerrno.h		pg_config_manual.h	postgres_ext.h
ecpglib.h		pg_config_os.h		postgresql
ecpgtype.h		pg_config_ppc.h		sql3types.h
libpq			pgtypes_date.h		sqlca.h
libpq-events.h		pgtypes_error.h
libpq-fe.h		pgtypes_interval.h
user-d0c71a:include langleys$
user-d0c71a:include langleys$ cd ../lib
user-d0c71a:lib langleys$ ls
libecpg.6.1.dylib		libpq.dylib
libecpg.6.dylib			libproj.0.5.5.dylib
libecpg.a			libproj.0.dylib
libecpg.dylib			libproj.dylib
libecpg_compat.3.1.dylib	libuuid.16.dylib
libecpg_compat.3.dylib		libuuid.a
libecpg_compat.a		libuuid.dylib
libecpg_compat.dylib		libuuid.la
libgeos-3.2.0.dylib		libxml2.2.7.1.dylib
libgeos.dylib			libxml2.2.dylib
libgeos_c.1.6.0.dylib		libxml2.a
libgeos_c.1.dylib		libxml2.dylib
libgeos_c.dylib			libxml2.la
libpgport.a			libxslt.1.1.23.dylib
libpgtypes.3.1.dylib		libxslt.1.dylib
libpgtypes.3.dylib		libxslt.a
libpgtypes.a			libxslt.dylib
libpgtypes.dylib		libxslt.la
libpq.5.2.dylib			postgis-1.4.so
libpq.5.dylib			postgresql
libpq.a
on the first line, you can clearly see that no matter which path I select
for "libdir" the configure script cannot find "libpq".  Any ideas?
Regards,
Shaun
On Jul 6, 2010, at 5:51 AM, Jorge Arévalo wrote:
> On Mon, Jul 5, 2010 at 6:15 PM, Shaun Langley <shaunlangley at gmail.com>
wrote:
>> it returns /Library/PostgreSQL/8.4/lib
>> what's the option syntax to add the lib directory during
>> configuration?  can I specify something like
>> --with-libdir='/Library/PostgreSQL/8.4/lib'
> The option should be --libdir='/Library/PostgreSQL/8.4/lib'. Give it a
> try
> Best regards,
> Jorge
>> Cheers,
>> Shaun
>> On Jul 5, 2010, at 11:51 AM, Jorge Arévalo wrote:
>>> On Mon, Jul 5, 2010 at 5:19 PM, Shaun Langley <shaunlangley at gmail.com>
wrote:
>>>> Yes it still complains it can't find libpq.
>>> I didn't try it on mac, but in Windows, I had to add the lib directory
to PATH.
>>> What happens if you execute pg_config --libdir?
>>>> Shaun Langley
>>>> Graduate Student
>>>> 208 Manly Miles
>>>> Michigan State University
>>>> East Lansing, MI 48824
>>>> (517) 974-9346
>>>> Sent from my iPad
>>>> On Jul 5, 2010, at 10:48 AM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
>>>>> So now that you had it manually does it still complain that it can not
find libpq?
>>>>> Some systems need us to explicit some installation paths (like
Windows) in the configure command.
>>>>> Pierre
>>>>>> [mailto:postgis-users- bounces at postgis.refractions.net] On Behalf
>>>>>> Of Shaun Langley
>>>>>> Sent: 2 juillet 2010 19:14
>>>>>> To: postgis-users
>>>>>> Subject: [postgis-users] WKT raster installation on mac
>>>>>> I'm trying to install WKT Raster on Mac OS X, using the
>>>>>> enterprisedb installation of postgres, and postgis through the
>>>>>> stackbuilder.  I've run into a problem when running the
>>>>>> ./configure for WKT Raster as it returns an error saying that it
>>>>>> cannot locate libpq.  The installation of postgres is found at
>>>>>> /Library/Postgres/8.4/ and libpq is located within lib/.  I had
>>>>>> to manully specify the location of pg_config which I did
successfully.  Any suggestions on how to proceed?
>>>>>> Regards,
>>>>>> Shaun
>>>>>> Shaun Langley
>>>>>> Graduate Student, PhD
>>>>>> Department of Geography
>>>>>> Home: (517) 974-9346
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Jorge Arévalo
>>> DEIMOS Space
>>> Internet & Mobilty Division
>>> Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º 28760 Tres
>>> Cantos (Madrid)
>>> Tel: +34 91 806 34 50 - ext: 155
>>> jorge.arevalo at deimos-space.com
>>> http://gis4free.wordpress.com
>> Shaun Langley
> Jorge Arévalo
> DEIMOS Space
> Cantos (Madrid)
Shaun Langley
