[postgis-users] ESRI union (analysis) in Postgis
Ralf Suhr
Ralf.Suhr at itc-halle.de
Thu Jul 8 00:44:15 PDT 2010
Hi Teresa,
you can't get a intersection from more then two polygons at a time. Think
about the attributes you get. The attributes are from poly1 and or poly2. The
solution is to use only datasources with non overlaping polygons.
Gr
Ralf
Am Donnerstag 08 Juli 2010, 09:27:06 schrieb Teresa Fazio:
> The solution you propose is valid to get polygons describing
> intersections between two polygons, but I cannot figure out how to
> obtain polygons describing intersections between more than two polygons
> like the central polygon drawn in the shape TEST_Union.
> I repeat that the TEST_Union shapefile was simply obtained using the
> "union (analysis)" tool in ESRI ArcGIS.
> Any other help?
> Thank you.
> postgis-users mailing list
