[postgis-users] Index on the Geomtery Column and GEOMETRYCOLLECTION EMPTY
    Mark Cave-Ayland
    mark.cave-ayland at siriusit.co.uk
    Thu Jul  8 02:37:52 PDT 2010
Sorin Dudui wrote:
> Hello,
> We have tables that contains both multi-polygons and empty geometries
> (MULTIPOLYGON EMPTY). The table has an index on the geometry column. After
> some updates with empty polygons the index becomes corrupt and we receive
> the error
> "Relate Operation called with a LWGEOMCOLLECTION type.  This is unsupported
> change argument GEOMETRYCOLLECTION EMPTY"
> when we make a spatial selection (ST_Intersects) with a polygon. ST_IsValid
> returns true for all geometries.
> If we delete the index the spatial query works without issues. For the
> moment our workaround is using permanent a  "not st_isEmpty) in the where
> clause.
> Thank you,
> Sorin
Hi Sorin,
In order to debug this, we need much more information such as the
versions of PostgreSQL/PostGIS you are using and a simple, reproducable
test case.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
