[postgis-users] shp2pgsql date quirk
Brian Hamlin
maplabs at light42.com
Fri Jul 9 00:02:14 PDT 2010
I am importing several large shape files, into pg 8.4 postgis 1.5+
most went in fine, but the last one failed with an error regarding date
fields.
At least one date field entry in the shape file apparently is "0"
pg complains, the conversion fails..
"Maybe you need different date settings" is suggested..
the database I am importing into already has 60+ tables..
I dont want to change settings on that database to accommodate..
suggestions on an efficient work-around?
thanks
-Brian
Brian Hamlin
planetwork.net
OSGeo California Chapter
(415) 717-4462 cell
