[postgis-users] shp2pgsql date quirk
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jul 9 01:32:51 PDT 2010
Brian Hamlin wrote:
> I am importing several large shape files, into pg 8.4 postgis 1.5+
> most went in fine, but the last one failed with an error regarding date
> fields.
> At least one date field entry in the shape file apparently is "0"
> pg complains, the conversion fails..
> "Maybe you need different date settings" is suggested..
> the database I am importing into already has 60+ tables..
> I dont want to change settings on that database to accommodate..
> suggestions on an efficient work-around?
> thanks
> -Brian
Hi Brian,
Could you provide us with a shapefile/dbf file containing a few of the
entries in question?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
