[postgis-users] QGIS SPIT import to POSTGIS -
Luís de Sousa luis.a.de.sousa at gmail.com
Mon Jul 12 10:58:08 PDT 2010
Hi Abe,
What version of QGis are you using? With 1.4 you need the following
for a user to add a layer from postgis:
. The layer correctly identified in the geometry_columns table;
. A primary key, or otherwise unique integer field, in the layer table;
. Usage premissions on the schema where the layer is;
. Select premissions on the layer itself;
With all this you should be able to load the layer into QGis.
Good luck,
Luís
On Fri, Jul 9, 2010 at 11:23 PM, rac88 <rac88 at hawaii.edu> wrote:
> I'm trying to use QGIS SPIT to load multiple shapefiles into PostGIS. But,
> for all users but my superuser, I can't see the non-public schemas.
> It sounds permission based but when I sign in as the user via PGAdmin or via
> psql I can access and view the schemas.
> The schemas were created within the postgis database so they should have the
> postgis extension - to confirm this I created a new schema from the public
> folder in the postgis database but this was not viewable either.
> I've included the schemas in the postgres.conf search_path also. And,
> geometry columns are in the public.geometry_column table.
> Line 478 of qgsspit.cpp is the only SQL reference to the namespace I can see
> (QString schemaSql = "select nspname from pg_namespace where
> has_schema_privilege(nspname, 'CREATE')";) and this works from both PGAdmin
> and psql. I also copied the function to the specific database and schema to
> determine if it was simply not finding the function but this didn't work
> either.
> Yes I can revert back to shp2pgsql but I like the multiple files option of
> SPIT - otherwise, can someone assist with some vb script or batch file to
> run shp2pgsql on files within a folder.
> Am I missing something else in the POSTGIS environment that may be
> restricting this user's ability?
> Thanks.
> Abe.
> View this message in context: http://old.nabble.com/QGIS-SPIT-import-to-POSTGIS---tp29122870p29122870.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
