[postgis-users] Execution plan with spatial index
Christian Beaumont chris at foundation42.org
Fri Jul 16 09:31:29 PDT 2010
Greetings,
I have a table with around a million rows with each row containing a *
geography* POINT (I'm covering the entire world).  With these rows I need to
perform many nearest neighbor searches to locate other entities within a
range of 0 to 100km.  The location field has a GiST index
With 5,000 records in the table my average query took around 0.5ms; however,
now I have a million records the query time has gone up to around 4ms.  I
did a reindex/vacuum etc.  My goal is to try and make this query as fast as
possible since it underpins everything I'm doing and the target hardware
won't be as powerful as my development box.
As well as the location column, I also have a "entity_type" column that is a
simple integer - 1, 2, ... (n)...
I figured I could improve performance by adding an index on
the entity_type column, then filter the rowset prior to nearest neighbor
search.  My logic was that it must be quicker to isolate a 10% subset of the
records using a simple integer index before feeding in to the expensive GiST
index.
Unfortunately when I did this, PostgresSQL didn't use my entity_type_idx at
all.  Instead, it did the nearest neighbor search using the GiST index, then
did a simple filter on the collected records based on the entity_type.  I
tried a few tricks to make it use the index but no-luck.
Any ideas for speeding this up would be very much appreciated!  Right now my
best idea would be to have separate tables for each entity type, but that
wouldn't be fun as I don't know the entity types in advance.
cheers,
-chris
Here is pseudo-code of the query and execution plan/analysis.  CB_GetPlace()
is one of my helper functions that returns a geography from an entity id
(marked *stable*).
*SELECT*
entity_id, category_id,
ST_Distance(location, CB_GetPlace(someEntityID)) as arcLength
*FROM* entities *WHERE*
category_id = 1 *AND*
ST_DWithin(location, CB_GetPlace(someEntityID), someRadius) *ORDER BY*arcLength;
"Sort  (cost=26.64..26.64 rows=1 width=140) (actual time=4.207..4.209
rows=16 loops=1)"
"  Sort Key: (_st_distance(location, cb_getplace(someEntityID::bigint),
0::double precision, true))"
"  Sort Method:  quicksort  Memory: 18kB"
"  ->  Index Scan using place_idx on "entities"  (cost=0.03..26.63 rows=1
width=140) (actual time=1.691..4.187 rows=16 loops=1)"
"        Index Cond: (location &&
_st_expand(cb_getplace(someEntityID::bigint), someRadius::double
precision))"
"        Filter: ((urt_id = 1) AND (cb_getplace(someEntityID::bigint) &&
_st_expand(location, someRadius::double precision)) AND
_st_dwithin(location, cb_getplace(someEntityID::bigint), someRadius::double
precision, true))"
"Total runtime: 4.242 ms"
If it matters, my test platform is PostGIS 1.5.1 with PostgreSQL 8.4.4-1
(Windows 32bit build) though my target platform is Ubuntu x64.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100716/5f369148/attachment.html>
