[postgis-users] shp2pgsql
Bob Pawley rjpawley at shaw.ca
Sat Jul 17 06:21:17 PDT 2010
Hi Regina
shp2pgsql.c 4867? 2009-1-20 ncayland $ Release: 1.4
It came with my brand new 8.4 download with which I have had more install
and "getting going" problems than any other Postgresql download.
Not being anywhere near a Postgresql expert these problems take me a lot of
time to overcome.
I applaud those who are working on them.
Bob
Sent: Friday, July 16, 2010 10:19 PM
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users] shp2pgsql
> Bob,
> Copy is better.  So copy the file as William said, and rename the new copy
> libiconv2.dll.
> Some programs refer to it by libiconv-2.dll and some as libiconv2.dll.
> It's
> a complicated story, but they  are generally interchangeable.
> However if you simply rename the existing, you'll break some other
> application.
> Its sounds like you are running an older shp2pgsql though because I think
> in
> later versions we changed to libiconv-2.dll to be consistent with
> PostgreSQL
> windows build
> Can you when you have your system working, at dos prompt do a
> shp2pgsql
> And let us know the version number it returns at top.
> It's the part that reads like
> RCSID: $Id: shp2pgsql-core.h 5098 2010-01-04 05:47:04Z pramsey $ RELEASE:
> 1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> Thanks,
> Leo and Regina
> http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
> Pawley
> Sent: Friday, July 16, 2010 12:46 PM
> To: will at thearete.co.uk; PostGIS Users Discussion
> I'm not sure what you mean by - "copy libiconv-2.dll to
>> libiconv2.dll."
> Do you mean rename??
> Bob
> From: "William Furnass" <will at thearete.co.uk>
> Sent: Friday, July 16, 2010 9:00 AM
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>> Hi Bob,
>> On 16 July 2010 16:46, Bob Pawley <rjpawley at shaw.ca> wrote:
>>> I just attempted to use shp2pgsql and received an error message about
>>> libiconv2.dll  not being installed on my computer.
>> If you've got PostgreSQL installed then you should already have a copy
>> of the library.  Find the 'bin' directory within your PostgreSQL
>> installation e.g. C:\PostgreSQL\8.4\bin and copy libiconv-2.dll to
>> libiconv2.dll.  Also, make sure that your PATH variable includes that
>> 'bin' directory (check with 'echo %PATH%' from a DOS prompt).
>> HTH,
>> Will
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
