[postgis-users] shp2pgsql
Paragon Corporation
lr at pcorp.us
Fri Jul 16 22:19:49 PDT 2010
Bob,
Copy is better. So copy the file as William said, and rename the new copy
libiconv2.dll.
Some programs refer to it by libiconv-2.dll and some as libiconv2.dll. It's
a complicated story, but they are generally interchangeable.
However if you simply rename the existing, you'll break some other
application.
Its sounds like you are running an older shp2pgsql though because I think in
later versions we changed to libiconv-2.dll to be consistent with PostgreSQL
windows build
Can you when you have your system working, at dos prompt do a
shp2pgsql
And let us know the version number it returns at top.
It's the part that reads like
RCSID: $Id: shp2pgsql-core.h 5098 2010-01-04 05:47:04Z pramsey $ RELEASE:
1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
Thanks,
Leo and Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Friday, July 16, 2010 12:46 PM
To: will at thearete.co.uk; PostGIS Users Discussion
Subject: Re: [postgis-users] shp2pgsql
I'm not sure what you mean by - "copy libiconv-2.dll to
> libiconv2.dll."
Do you mean rename??
Bob
Sent: Friday, July 16, 2010 9:00 AM
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Hi Bob,
> On 16 July 2010 16:46, Bob Pawley <rjpawley at shaw.ca> wrote:
>> I just attempted to use shp2pgsql and received an error message about
>> libiconv2.dll not being installed on my computer.
> If you've got PostgreSQL installed then you should already have a copy
> of the library. Find the 'bin' directory within your PostgreSQL
> installation e.g. C:\PostgreSQL\8.4\bin and copy libiconv-2.dll to
> libiconv2.dll. Also, make sure that your PATH variable includes that
> 'bin' directory (check with 'echo %PATH%' from a DOS prompt).
> HTH,
> Will
> postgis-users mailing list
