[postgis-users] shp2pgsql
Bob Pawley
rjpawley at shaw.ca
Fri Jul 16 09:46:06 PDT 2010
I'm not sure what you mean by - "copy libiconv-2.dll to
> libiconv2.dll."
Do you mean rename??
Bob
Sent: Friday, July 16, 2010 9:00 AM
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users] shp2pgsql
> Hi Bob,
> On 16 July 2010 16:46, Bob Pawley <rjpawley at shaw.ca> wrote:
>> I just attempted to use shp2pgsql and received an error message about
>> libiconv2.dll not being installed on my computer.
> If you've got PostgreSQL installed then you should already have a copy
> of the library. Find the 'bin' directory within your PostgreSQL
> installation e.g. C:\PostgreSQL\8.4\bin and copy libiconv-2.dll to
> libiconv2.dll. Also, make sure that your PATH variable includes that
> 'bin' directory (check with 'echo %PATH%' from a DOS prompt).
> HTH,
> Will
> postgis-users mailing list
