[postgis-users] WKTRaster : gdal2wktraster.py cannot read AIG/Arc/Info Binary Grid
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Jul 19 09:56:31 PDT 2010
Hi Sebastian,
I can convert ESRI Grid file to .sql without problem using gdal2wktraster.py and the same parameters as you. I can do both integer and floating point rasters.
Maybe this is a GDAL problem. Try to convert it using gdal_translate (to tiff for example). This would be a better test than just gdalinfo.
Could you provide us with a file sample?
Pierre
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sebastian E. Ovide
Sent: 19 juillet 2010 12:28
To: PostGIS Users Discussion
Subject: [postgis-users] WKTRaster : gdal2wktraster.py cannot read AIG/Arc/Info Binary Grid
Hi All,
trying to create a SQL with gdal2wktraster.py. It works on PNG but it doesn't on AIG files...
Note: As Gdal works fine.
C:\Program Files\PostgreSQL\8.4\bin>gdalinfo c:\tmp\raster
Driver: AIG/Arc/Info Binary Grid
Files: c:\tmp\raster
       c:\tmp\raster\dblbnd.adf
       c:\tmp\raster\hdr.adf
       c:\tmp\raster\metadata.xml
       c:\tmp\raster\prj.adf
       c:\tmp\raster\sta.adf
       c:\tmp\raster\vat.adf
       c:\tmp\raster\w001000.adf
       c:\tmp\raster\w001000x.adf
       c:\tmp\raster\w001001.adf
       c:\tmp\raster\w001001x.adf
       c:\tmp\raster\z001001.adf
       c:\tmp\raster\z001001x.adf
       c:\tmp\raster\z001002.adf
       c:\tmp\raster\z001002x.adf
       c:\tmp\raster\z001003.adf
       c:\tmp\raster\z001003x.adf
       c:\tmp\raster\z001004.adf
       c:\tmp\raster\z001004x.adf
       c:\tmp\raster\z001005.adf
       c:\tmp\raster\z001005x.adf
       c:\tmp\raster\z001006.adf
       c:\tmp\raster\z001006x.adf
       c:\tmp\raster\z001007.adf
       c:\tmp\raster\z001007x.adf
       c:\tmp\raster\z001008.adf
       c:\tmp\raster\z001008x.adf
       c:\tmp\raster\z001009.adf
       c:\tmp\raster\z001009x.adf
       c:\tmp\raster\z001010.adf
       c:\tmp\raster\z001010x.adf
       c:\tmp\raster\z001011.adf
       c:\tmp\raster\z001011x.adf
       c:\tmp\raster\z001012.adf
       c:\tmp\raster\z001012x.adf
       c:\tmp\raster\z001013.adf
       c:\tmp\raster\z001013x.adf
       c:\tmp\raster\z001014.adf
       c:\tmp\raster\z001014x.adf
       c:\tmp\raster\z001015.adf
       c:\tmp\raster\z001015x.adf
Size is 107759, 168633
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["Unknown datum based upon the Airy 1830 ellipsoid",
        DATUM["Not_specified_based_on_Airy_1830_ellipsoid",
            SPHEROID["Airy 1830",6377563.396,299.3249646,
                AUTHORITY["EPSG","7001"]],
            AUTHORITY["EPSG","6001"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.01745329251994328,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4001"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",49],
    PARAMETER["central_meridian",-2],
    PARAMETER["scale_factor",0.9996012717],
    PARAMETER["false_easting",400000],
    PARAMETER["false_northing",-100000],
    UNIT["METERS",1]]
Origin = (128110.000000000000000,813270.000000000000000)
Pixel Size = (5.000000000000000,-5.000000000000000)
Corner Coordinates:
Upper Left  (  128110.000,  813270.000) (  6d29'37.32"W, 57d 7'47.53"N)
Lower Left  (  128110.000,  -29895.000) (  5d45'40.00"W, 49d34'10.24"N)
Upper Right (  666905.000,  813270.000) (  2d24'41.72"E, 57d 7'58.04"N)
Lower Right (  666905.000,  -29895.000) (  1d41'32.29"E, 49d34'18.23"N)
Center      (  397507.500,  391687.500) (  2d 2'15.04"W, 53d25'18.19"N)
Band 1 Block=256x4 Type=Byte, ColorInterp=Undefined
  Min=1.000 Max=4.000
  NoData Value=255
C:\Program Files\PostgreSQL\8.4\bin>python gdal2wktraster.py -r c:\tmp\raster -t sebastable -o c:\tmp\sebas.sql
gdal2wktraster.py:644: DeprecationWarning: 'H' format requires 0 <= number <= 65535
  hexstr = binascii.hexlify(struct.pack(fmt_little, data)).upper()
gdal2wktraster.py:644: DeprecationWarning: integer argument expected, got float
ERROR 2: Multiplication overflow : 107759 * 168633 * 1
  File "gdal2wktraster.py", line 1013, in <module>
    main()
  File "gdal2wktraster.py", line 976, in main
    wkblify_raster(opts, filename, i)
  File "gdal2wktraster.py", line 921, in wkblify_raster
    summary = wkblify_raster_level(options, ds, options.overview_level, band_range, infile, i)
  File "gdal2wktraster.py", line 888, in wkblify_raster_level
    hexwkb += wkblify_band(options, band, level, xoff, yoff, read_block_size, block_size, infile, b)
  File "gdal2wktraster.py", line 777, in wkblify_band
    target_block_size[0], target_block_size[1])
  File "C:\OSGeo4W\apps\gdal-16\pymod\osgeo\gdal.py", line 835, in ReadAsArray
    buf_xsize, buf_ysize, buf_obj )
  File "C:\OSGeo4W\apps\gdal-16\pymod\osgeo\gdal_array.py", line 140, in BandReadAsArray
    ar = numpy.reshape(ar, [buf_ysize,buf_xsize])
  File "C:\OSGeo4W\apps\Python25\lib\site-packages\numpy\core\fromnumeric.py", line 116, in reshape
    return reshape(newshape, order=order)
ValueError: total size of new array must be unchanged
Any ideas ?
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100719/bd3c1722/attachment.html>
