[postgis-users] WKTRaster : gdal2wktraster.py cannot read AIG/Arc/Info Binary Grid
Sebastian E. Ovide
sebastian.ovide at gmail.com
Tue Jul 20 02:51:20 PDT 2010
Hi Pierre,
Does gdal2wktraster.py have any limitation on the maximum number of
columnsxrows ?
in my case, my raster is 107759 x 168633...
gdal works well:
sebas at SeansPC:~/rasters$ gdal_translate -of PNG raster/ test.png
Input file size is 107759, 168633
0...10...20...30...40...50...60...70...80...90...100 - done.
sebas at SeansPC:~/rasters$ python gdal2wktraster.py -r raster/ -t sebastable
-o ok.sql
gdal2wktraster.py:695: DeprecationWarning: 'H' format requires 0 <= number
<= 65535
hexwkb += wkblify('H', xsize)
gdal2wktraster.py:696: DeprecationWarning: 'H' format requires 0 <= number
<= 65535
hexwkb += wkblify('H', ysize)
gdal2wktraster.py:727: DeprecationWarning: integer argument expected, got
float
hexwkb += wkblify(pt2fmt(pixtype), nodata)
File "gdal2wktraster.py", line 1013, in <module>
main()
File "gdal2wktraster.py", line 976, in main
wkblify_raster(opts, filename, i)
File "gdal2wktraster.py", line 921, in wkblify_raster
summary = wkblify_raster_level(options, ds, options.overview_level,
band_range, infile, i)
File "gdal2wktraster.py", line 888, in wkblify_raster_level
hexwkb += wkblify_band(options, band, level, xoff, yoff,
read_block_size, block_size, infile, b)
File "gdal2wktraster.py", line 777, in wkblify_band
target_block_size[0], target_block_size[1])
File "/usr/lib/python2.6/dist-packages/osgeo/gdal.py", line 895, in
ReadAsArray
buf_xsize, buf_ysize, buf_obj )
File "/usr/lib/python2.6/dist-packages/osgeo/gdal_array.py", line 228, in
BandReadAsArray
ar = numpy.empty([buf_ysize,buf_xsize], dtype = typecode)
MemoryError
sebas at SeansPC:~/rasters$ python gdal2wktraster.py -r test.png -t sebastable
-o ok.sql
<= 65535
<= 65535
float
main()
ReadAsArray
BandReadAsArray
MemoryError
On Mon, Jul 19, 2010 at 5:56 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> Hi Sebastian,
> I can convert ESRI Grid file to .sql without problem using
> gdal2wktraster.py and the same parameters as you. I can do both integer and
> floating point rasters.
> Maybe this is a GDAL problem. Try to convert it using gdal_translate (to
> tiff for example). This would be a better test than just gdalinfo.
> Could you provide us with a file sample?
> Pierre
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Sebastian E.
> Ovide
> *Sent:* 19 juillet 2010 12:28
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] WKTRaster : gdal2wktraster.py cannot read
> Hi All,
> trying to create a SQL with gdal2wktraster.py. It works on PNG but it
> doesn't on AIG files...
> Note: As Gdal works fine.
> C:\Program Files\PostgreSQL\8.4\bin>gdalinfo c:\tmp\raster
> Driver: AIG/Arc/Info Binary Grid
> Files: c:\tmp\raster
> c:\tmp\raster\dblbnd.adf
> c:\tmp\raster\hdr.adf
> c:\tmp\raster\metadata.xml
> c:\tmp\raster\prj.adf
> c:\tmp\raster\sta.adf
> c:\tmp\raster\vat.adf
> c:\tmp\raster\w001000.adf
> c:\tmp\raster\w001000x.adf
> c:\tmp\raster\w001001.adf
> c:\tmp\raster\w001001x.adf
> c:\tmp\raster\z001001.adf
> c:\tmp\raster\z001001x.adf
> c:\tmp\raster\z001002.adf
> c:\tmp\raster\z001002x.adf
> c:\tmp\raster\z001003.adf
> c:\tmp\raster\z001003x.adf
> c:\tmp\raster\z001004.adf
> c:\tmp\raster\z001004x.adf
> c:\tmp\raster\z001005.adf
> c:\tmp\raster\z001005x.adf
> c:\tmp\raster\z001006.adf
> c:\tmp\raster\z001006x.adf
> c:\tmp\raster\z001007.adf
> c:\tmp\raster\z001007x.adf
> c:\tmp\raster\z001008.adf
> c:\tmp\raster\z001008x.adf
> c:\tmp\raster\z001009.adf
> c:\tmp\raster\z001009x.adf
> c:\tmp\raster\z001010.adf
> c:\tmp\raster\z001010x.adf
> c:\tmp\raster\z001011.adf
> c:\tmp\raster\z001011x.adf
> c:\tmp\raster\z001012.adf
> c:\tmp\raster\z001012x.adf
> c:\tmp\raster\z001013.adf
> c:\tmp\raster\z001013x.adf
> c:\tmp\raster\z001014.adf
> c:\tmp\raster\z001014x.adf
> c:\tmp\raster\z001015.adf
> c:\tmp\raster\z001015x.adf
> Size is 107759, 168633
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["Unknown datum based upon the Airy 1830 ellipsoid",
> DATUM["Not_specified_based_on_Airy_1830_ellipsoid",
> SPHEROID["Airy 1830",6377563.396,299.3249646,
> AUTHORITY["EPSG","7001"]],
> AUTHORITY["EPSG","6001"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.01745329251994328,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4001"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",49],
> PARAMETER["central_meridian",-2],
> PARAMETER["scale_factor",0.9996012717],
> PARAMETER["false_easting",400000],
> PARAMETER["false_northing",-100000],
> UNIT["METERS",1]]
> Origin = (128110.000000000000000,813270.000000000000000)
> Pixel Size = (5.000000000000000,-5.000000000000000)
> Corner Coordinates:
> Upper Left ( 128110.000, 813270.000) ( 6d29'37.32"W, 57d 7'47.53"N)
> Lower Left ( 128110.000, -29895.000) ( 5d45'40.00"W, 49d34'10.24"N)
> Upper Right ( 666905.000, 813270.000) ( 2d24'41.72"E, 57d 7'58.04"N)
> Lower Right ( 666905.000, -29895.000) ( 1d41'32.29"E, 49d34'18.23"N)
> Center ( 397507.500, 391687.500) ( 2d 2'15.04"W, 53d25'18.19"N)
> Band 1 Block=256x4 Type=Byte, ColorInterp=Undefined
> Min=1.000 Max=4.000
> NoData Value=255
> C:\Program Files\PostgreSQL\8.4\bin>python gdal2wktraster.py -r
> c:\tmp\raster -t sebastable -o c:\tmp\sebas.sql
> gdal2wktraster.py:644: DeprecationWarning: 'H' format requires 0 <= number
> <= 65535
> hexstr = binascii.hexlify(struct.pack(fmt_little, data)).upper()
> gdal2wktraster.py:644: DeprecationWarning: integer argument expected, got
> float
> ERROR 2: Multiplication overflow : 107759 * 168633 * 1
> main()
> File "C:\OSGeo4W\apps\gdal-16\pymod\osgeo\gdal.py", line 835, in
> ReadAsArray
> File "C:\OSGeo4W\apps\gdal-16\pymod\osgeo\gdal_array.py", line 140, in
> BandReadAsArray
> ar = numpy.reshape(ar, [buf_ysize,buf_xsize])
> File
> "C:\OSGeo4W\apps\Python25\lib\site-packages\numpy\core\fromnumeric.py", line
> 116, in reshape
> return reshape(newshape, order=order)
> ValueError: total size of new array must be unchanged
> Any ideas ?
> Sebastian E. Ovide
> postgis-users mailing list
Sebastian E. Ovide
skype: sebastian.ovide
+353 (0) 87 6340149
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100720/2208de81/attachment.html>
