[postgis-users] intersect operation in 3d?
Hugh Stimson hugh at hughstimson.org
Mon Jul 19 15:14:49 PDT 2010
Thanks for your reply Ralf.
Since posting my query I've found this helpful chart of functions with their 2.5d support:
http://postgis.refractions.net/docs/ch08.html#PostGIS_TypeFunctionMatrix
According to that, the ST_Intersects and ST_Intersection functions aren't yet 2.5d enabled.  So I'm guessing that means that while they will accept data with an assigned Z, as you suggest, only the x/y dimensions will be considered in determining if they are coincident.
That isn't sufficient for the application I'm working on, I need to be able to distinguish the case where one object passes over another one without actually touching. The shapes involved are complex enough that using a simple elevation rule to pre-filter can't account for all possible situations.
Might have to shell out the big bucks for an ESRI license. Ouch.
cheers, Hugh
> Hi Hugh,
> all functions in PostGIS will work on 2.5D data. So you have to add an extra
> condition for your z-range.
> Gr
> Ralf
> Am Freitag 16 Juli 2010, 23:32:03 schrieb Hugh Stimson:
>> Hi PostGIS folks,
>> I'm trying to find a way to read two 3-dimensional polygons and test if
>> they intersect. It's for a radar-bird-tracking application. I'm hoping
>> that PostGIS is a solution.
>> I've been scanning the Mailing list archives, and I gather that at least
>> some of the spatial operations which PostGIS provides are 3d-enabled.
>> Which surprises me, as my understanding was that PostGIS spatial
>> operations descend from the Java Topological Suite via GEOS, and JTS
>> advertises itself as being specifically for 2-d linear modelling.
>> Could I count on the ST_Intersects function to work with 3d data? Would
>> there likely be any special considerations for 3d?
>> http://postgis.refractions.net/documentation/manual-1.5/ST_Intersects.html
>> cheers,
>> Hugh
Hugh Stimson / 778.373.1024 / hughstimson.org
