[postgis-users] WKT raster installation on Mac Snow Leopard
William Kyngesburye woklist at kyngchaos.com
Tue Jul 20 12:38:28 PDT 2010
On Jul 20, 2010, at 2:11 PM, Javier de la Torre wrote:
> I have tried downloading the same version of PostGIS code that I have installed via Kyngchaos and use it to compile WKT raster. I had to copy config.sub and config.guess because it was complaining and then I ran:
Odd.  The included config.sub/guess work for me.
> ./configure --with-postgis-sources=/Users/jatorre/workspace/postgis-1.5.1/ --with-pgconfig=/usr/local/pgsql/bin/pg_config --with-gdal=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config --with-geos=/Library/Frameworks/GEOS.framework/unix/bin/geos-config
> But the error I get is:
> ld: symbol(s) not found for architecture i386
> collect2: ld returned 1 exit status
> ld: warning: directory '/Users/Shared/unix/gettext-snow/lib' following -L not found
Looks like I forgot to clean part of the Postgres installation before packaging it up.  That's a local library that I bundle in the Postgres distribution.  Watch my site for an update...
> If I try to compile postgis I get the same error.
> I took a look at how the sources from kyngchaos were created (http://www.kyngchaos.com/macosx/build/postgis) but they are not up to date with Snow Leopard.
Yes, I've been lazy here ;)
postgis:
export MACOSX_DEPLOYMENT_TARGET=10.6
export CFLAGS="-Os -arch i386 -arch x86_64"
export PG_CPPFLAGS="-arch i386 -arch x86_64"
export SHLIB_LINK="-arch i386 -arch x86_64"
export LDFLAGS="-arch i386 -arch x86_64"
./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config \
--with-geosconfig=/Library/Frameworks/GEOS.framework/Programs/geos-config \
--with-projdir=/Library/Frameworks/PROJ.framework/unix
wktraster:
--with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config \
--with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config \
... hmm, it seems there is some interest in WKTraster on OS X... maybe it's time for a new package...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
The equator is so long, it could encircle the earth completely once.
