[postgis-users] gdal2wktraster
George Silva georger.silva at gmail.com
Wed Jul 21 05:24:22 PDT 2010
Hello guys,
I'm using: "POSTGIS="1.4.0" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21
August 2008" USE_STATS" with PostgreSQL 8.3 and* *I'm having some problems
using gdal2wktraster.
I have successfully installed WKTRaster:
postgis_raster_lib_build_date()
"2010-06-21 17:52:45"
postgis_raster_lib_version()
"0.1.6d"
And I have installed the PyPi file from the address below:
http://pypi.python.org/pypi/GDAL/1.6.1
Gdal installs just fine too, but when I try:
C:\Python25\python gdal2wktraster.py -help
I get a MessageBox, saying: "This application has failed to start because
gdal16.dll was not found. re-installing the application may fix this
problem". I already reinstalled it, but still no success.
The response on the command prompt is:
  File "gdal2wktraster.py", line 32, in <module>
    from osgeo import gdal
  File "C:\Python25\Lib\site-packages\osgeo\gdal.py", line 7, in <module>
    import _gdal
ImportError: DLL load failed: The specified module could not be found
I've checked the file, and it's already there. There is a GDAL .dll file in
my Python25 folder, libgdal.dll. Could this be the "gdal16.dll"?
Many thanks,
George
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100721/91d3fcdc/attachment.html>
