[postgis-users] gdal2wktraster.py wildchar not working
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Jul 21 08:26:14 PDT 2010
Sabastian,
This is strange... They are all in the same folder? How many there are? As a test, does it work if there is only 2?
Where did you get WKT Raster? Do you have the last version?
What if you do: gdal2wktraster.py --version
If you could reduce the big raster to a smaller one which repeat the original bug and provide it to us use it would be very useful.
Also, normally you will also want to retile your smaller rasters with the -k option to tiles (something like 100x100 or 200x200), specify the reference system with the -s option and create an index with the -I option. Did you read the tutorial?
Pierre
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sebastian E. Ovide
Sent: 21 juillet 2010 04:15
To: PostGIS Users Discussion
Subject: [postgis-users] gdal2wktraster.py wildchar not working
Hi All,
as gdal2wktraster.py has a bug that prevents importing big rasters, I have split the raster using
I created a lot of tif files...
then I've tried to create a sql with this:
./gdal2wktraster.py -r test/*.tif -t newtable -o newtable.sql
and gdal2wktraster.py read only 1 file:
sebas at SeansPC:~/rasters$ ./gdal2wktraster.py -r test/*.tif -t newtable -o newtable.sql
 Summary of GDAL to WKT Raster processing:
Number of processed raster files: 1 (test/test_01_01.tif)
List of generated tables (number of tiles):
1       newtable (1)
any other easy way to import big rasters ?
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100721/427e2dda/attachment.html>
