[postgis-users] gdal2wktraster.py wildchar not working
Jorge Arévalo
jorge.arevalo at deimos-space.com
Thu Jul 22 07:05:31 PDT 2010
Hi Sebastian,
On Wed, Jul 21, 2010 at 6:35 PM, Sebastian E. Ovide
<sebastian.ovide at gmail.com> wrote:
>> Also, normally you will also want to retile your smaller rasters with the
>> –k option to tiles (something like 100x100 or 200x200), specify the
>> reference system with the –s option and create an index with the –I option.
>> Did you read the tutorial?
> it should not matter for gdal2wktraster.py right ?
Could you please provide a link to download the big raster that caused
the first problem in Linux? We're trying to reproduce it, in the same
conditions. You should be able to deal with big rasters by splitting
them into small blocks by using -k option to specify the size of the
blocks, and -I option to create an index, without using any other tool
before.
About the wildcard problem, we're working on it too. Thanks for reporting it.
Best regards,
Jorge
>> Pierre
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Sebastian E. Ovide
>> Sent: 21 juillet 2010 04:15
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] gdal2wktraster.py wildchar not working
>> Hi All,
>> as gdal2wktraster.py has a bug that prevents importing big rasters, I have
>> split the raster using
>> I created a lot of tif files...
>> then I've tried to create a sql with this:
>> ./gdal2wktraster.py -r test/*.tif -t newtable -o newtable.sql
>> and gdal2wktraster.py read only 1 file:
>> sebas at SeansPC:~/rasters$ ./gdal2wktraster.py -r test/*.tif -t newtable -o
>> newtable.sql
>> Summary of GDAL to WKT Raster processing:
>> Number of processed raster files: 1 (test/test_01_01.tif)
>> List of generated tables (number of tiles):
>> 1 newtable (1)
>> any other easy way to import big rasters ?
>> Sebastian E. Ovide
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Sebastian E. Ovide
