[postgis-users] gdal2wktraster.py wildchar not working
Sebastian E. Ovide
sebastian.ovide at gmail.com
Fri Jul 23 01:12:34 PDT 2010
Agree...
by the way, the script finished in only 10 minutes and it has created a file
of 35GB ! Still I cannot compare it with Oracle as I do not know yet how
much space it will consume inside PG (in oracle it consumes around 16GB if
not compressed and around 300M if compressed)
sebas at SeansPC:~/rasters$ ls -lh ok.sql
-rw-r--r-- 1 sebas sebas 35G 2010-07-22 17:52 ok.sql
running the sql with psql I'm getting only errors:
sebas at SeansPC:~/rasters$ time psql -d sebas -h 10.0.1.50 -U sebas -f ok.sql
BEGIN
psql:ok.sql:2: NOTICE: CREATE TABLE will create implicit sequence
"sebastable_rid_seq" for serial column "sebastable.rid"
psql:ok.sql:2: NOTICE: CREATE TABLE / PRIMARY KEY will create implicit
index "sebastable_pkey" for table "sebastable"
CREATE TABLE
psql:ok.sql:3: ERROR: Invalid SRID
CONTEXT: SQL statement "SELECT AddRasterColumn('', $1 , $2 , $3 , $4 , $5 ,
$6 , $7 , $8 , $9 , $10 , $11 , $12 , $13 )"
PL/pgSQL function "addrastercolumn" line 4 at SQL statement
psql:ok.sql:4: ERROR: current transaction is aborted, commands ignored
until end of transaction block
psql:ok.sql:5: ERROR: current transaction is aborted, commands ignored
psql:ok.sql:6: ERROR: current transaction is aborted, commands ignored
psql:ok.sql:7: ERROR: current transaction is aborted, commands ignored
psql:ok.sql:8: ERROR: current transaction is aborted, commands ignored
psql:ok.sql:9: ERROR: current transaction is aborted, commands ignored
p
any ideas ?
On Thu, Jul 22, 2010 at 6:55 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> Well it's still a bug that the process fail without the -k option, but we
> can lower the priority. If we could have one of those rasters...
> Pierre
> >-----Original Message-----
> >From: postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-
> >bounces at postgis.refractions.net] On Behalf Of Jorge Arévalo
> >Sent: 22 juillet 2010 12:56
> >To: PostGIS Users Discussion
> >Subject: Re: [postgis-users] gdal2wktraster.py wildchar not working
> >On Thu, Jul 22, 2010 at 6:45 PM, Sebastian E. Ovide
> ><sebastian.ovide at gmail.com> wrote:
> >> Hi Jorge,
> >> running the same gdal2wktraster script with those options that have
> >> suggested have fixed the error...
> >> i.e:
> >> sebas at SeansPC:~/rasters$ time ./gdal2wktraster.py -k 512x512 -s 81989
> -I -r
> >> raster/ -t sebastable -o ok.sql
> >> ./gdal2wktraster.py:727: DeprecationWarning: integer argument expected,
> got
> >> float
> >> hexwkb += wkblify(pt2fmt(pixtype), nodata)
> >> that means that if the image is too big, "-k is mandatory" (probably it
> >> should be set with some default...)
> >> I have to go now.. if it gives any error I'll let you know !
> >> thanks
> >Great. So, we only have to focus on the wildcard problem. Keep us
> >informed if you experiment more problems :-)
> >Best regards,
> >Jorge
> >> 2010/7/22 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> >>> Hi Sebastian,
> >>> On Wed, Jul 21, 2010 at 6:35 PM, Sebastian E. Ovide
> >>> >> Also, normally you will also want to retile your smaller rasters
> with
> >>> >> the
> >>> >> -k option to tiles (something like 100x100 or 200x200), specify the
> >>> >> reference system with the -s option and create an index with the -I
> >>> >> option.
> >>> >> Did you read the tutorial?
> >>> > it should not matter for gdal2wktraster.py right ?
> >>> Could you please provide a link to download the big raster that caused
> >>> the first problem in Linux? We're trying to reproduce it, in the same
> >>> conditions. You should be able to deal with big rasters by splitting
> >>> them into small blocks by using -k option to specify the size of the
> >>> blocks, and -I option to create an index, without using any other tool
> >>> before.
> >>> About the wildcard problem, we're working on it too. Thanks for
> reporting
> >>> it.
> >>> Best regards,
> >>> Jorge
> >>> >> Pierre
> >>> >> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> >>> >> Sebastian E. Ovide
> >>> >> Sent: 21 juillet 2010 04:15
> >>> >> Subject: [postgis-users] gdal2wktraster.py wildchar not working
> >>> >> Hi All,
> >>> >> as gdal2wktraster.py has a bug that prevents importing big rasters,
> I
> >>> >> have
> >>> >> split the raster using
> >>> >> I created a lot of tif files...
> >>> >> then I've tried to create a sql with this:
> >>> >> ./gdal2wktraster.py -r test/*.tif -t newtable -o newtable.sql
> >>> >> and gdal2wktraster.py read only 1 file:
> >>> >> sebas at SeansPC:~/rasters$ ./gdal2wktraster.py -r test/*.tif -t
> newtable
> >>> >> -o
> >>> >> newtable.sql
> >>> >> Summary of GDAL to WKT Raster processing:
> >>> >> Number of processed raster files: 1 (test/test_01_01.tif)
> >>> >> List of generated tables (number of tiles):
> >>> >> 1 newtable (1)
> >>> >> any other easy way to import big rasters ?
> >>> >> Sebastian E. Ovide
> >>> >> _______________________________________________
> >>> >> postgis-users mailing list
> >>> >> postgis-users at postgis.refractions.net
> >>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>> > Sebastian E. Ovide
> >> Sebastian E. Ovide
Sebastian E. Ovide
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100723/36e7ec2e/attachment.html>
