[postgis-users] JASPA (JAva SPATial) for PostgreSQL and H2released. HSQLDB is planned to be supported.
muhammad imran
imranserver at yahoo.com
Sat Jul 24 16:16:03 PDT 2010
One solid point that I was keen to look so far is that the new opportunity for integration java-based technologies with the database, for instance, as Jose mentioned the geotools. Furthermore, since Oracle is the leading commercial database solution provider and it supports the java technology so a new opportunity for attracting the professionals that may lead to the emerging of bigger communities.
Best,
Imran
--- On Sat, 7/24/10, José Carlos Martínez <jomarlla at cgf.upv.es> wrote:
> From: José Carlos Martínez <jomarlla at cgf.upv.es>
> Subject: Re: [postgis-users] JASPA (JAva SPATial) for PostgreSQL and H2released. HSQLDB is planned to be supported.
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Saturday, July 24, 2010, 11:11 PM
> Hi all,
> Paragon Corporation escribió:
> > Muhammad,
> > We don't know too much about JASPA project, but here
> is our general feeling
> > based on the underlying architecture and quick glance
> at the docs.
> > From our general understanding JASPA implements all
> its PostgreSQL functions
> > using Java stored procs. There are several
> consequences of this some good
> > and some bad
> > The Good
> > 1) JASPA uses JTS directly so doesn't suffer
> from the need to port JTS
> > functionality to GEOS. So you will probably see
> new features introduced in
> > JTS in Jaspa sooner than you will see it in PostGIS.
> yes I think so but jaspa uses a slightly modifed version of
> JTS. Some changes:
> wkb/ewkb/wkt/ewkt
> M/Z handle
> Anyways, a JTS original library can be modified in less
> than one hour.
> > 2) Good/Bad -- Not tied to a specific database
> platform (though it only
> > really supports PostgreSQL/HSQL at the moment) -- I
> kind of consider this a
> > good/bad of rasdaman as well. Its good in the
> sense that you can run it in
> > other databases, but bad in the sense that your
> architecture is either more
> > complicated and/or you don't play as nicely with the
> native functionality a
> > database offers. JASPA its not quite as much of
> an issue as it is for
> > rasdaman since the functions are implemented as
> PostgreSQL stored functions
> > and can use just like you use PostGIS functions.
> I understand your point of view but one of the goal (I
> think the most important one) of jaspa
> is to aim to be easier to extend than postgis even for a
> not computer science expertice
> and to be able to use different databases. Im not talkig
> about plpgsql (this one is easy) but
> lwgeom, geos, native postgres funtions, etc.
> The proof that jaspa is easier to extend is: just with
> 22000 lines of code jaspa does almost everything postgis1.4
> does.
> and its been developped just for one person in one year
> (of course thanks to the use of other open source projects
> as postgis, jts, geotools, etc.)
> I think it means jaspa is really easy to extend and to
> support new functionalities.
> Another point is GeoTools which I think its another
> stargate for new functionalities.
> > 3) They seem to implement a lot of things above the
> core JTS -
> > http://jaspa.forge.osor.eu/Introduction.html#id474917
> > Like Delaunay triangles and some topology.
> Sounds interesting.
> > http://jaspa.forge.osor.eu/ST_DelaunayTriangles.html
> Jaspa supports some JTS 1.11 new functionality as you said
> for example delaunay triangles.
> Of course this is not a jaspa praiseworthy as it is a JTS
> merit.
> From jaspa 0.1 we will start developing new functionalities
> as:
> - hibrid topology
> - topology rules
> - cluster/tolerance
> - geodesic support
> > They claim PostGIS 1.4 compatibility, but not sure if
> that means 100% -- it
> > does look like they do support at least ST_Dump
> functions (and have
> > implemented some of the PostGIS non-geography
> functions)
> > http://jaspa.forge.osor.eu/differences.html#id498020
> About PostGIS 1.4 compatibily I meant that almost all the
> postgis methods are implemented in jaspa. It is not 100% but
> it is close to that. Around 94% of the postgis methods work
> in jaspa. Im working in postgis long transaction methods
> (they are already implemented but i need a pljava patch to
> support to cancel triggers..luca ferrari did one
> already)..with the long transaction methods the supported
> functions are 97%.
> > The Bad
> > While PostgreSQL does support java stored procs, its
> not a common choice.
> > I'm not sure exactly why. As I recall a while
> back -- it had something to
> > do with the way Java classes were created and so forth
> similar to why .NET
> > is not a supported option in PostgreSQL. Times have
> changed though so may
> > not be a bad option now. This means
> > A) Most likely it will be harder to install on all
> platforms.
> yes I agree, but
> Pljava will support postgres 9 at least. Hope jaspa
> project helps to keep pljava project running too.
> Anyways, we are just talking about postgres but
> H2 is easier in this sense and I hope we can develop jaspa
> for hsqldb soon.
> The huge problem now: h2 and hsqldb do not support
> spatial indexes.
> > B) Not as tried and tested as C binding
> functions. So things such as memory
> > management between the core PostgreSQL layer and
> library layer I suspect
> > will be better in PostGIS than they are in JASPA.
> yes I think so. pljava is not as fast as directly accessing
> sql types from c and
> jaspa is not c. Anyways if you check the performance its
> not bad at all, and
> the performance about some methods can be surprising.
> > C) There are lots of functions implemented directly in
> PostGIS that are not
> > in JTS or GEOS (and GEOS is not a direct port in and
> of itself of JTS -- it
> > has some 3D glue that JTS lacks). Example are my
> favorite functions
> > implemented directly in PostGIS - All the
> geography support introduced in
> > PostGIS 1.5, ST_ClosestPoint (native PostGIS),
> ST_AsGML/ST_GeomFromGML/KML,
> > ST_Dump functions etc.
> > I would say about 50 percent of the functions in
> PostGIS are not derived
> > from JTS/GEOS though there are some overlaps like
> ST_Distance that PostGIS
> > chose to reimplement because it was more efficient
> than using the JTS/GEOS.
> > I'm not sure if Jaspa implements these on their own or
> not. It looks like
> > from their documentation they try to be very
> compatible with PostGIS.
> The not GEOS/JTS derived functions are working in jaspa
> too, as I said before 94% of the postgis 1.4 methods are
> working in jaspa.
> Jaspa functions can be divided in:
> - functions which map JTS functions directly. e. g.:
> st_area
> - functions which use JTS objects aimplementing some
> functionality. e. g.: st_addpoint, st_dump
> - functions which combine other JTS functions: e. g.:
> ST_Nodeline, ST_CleanPolygons
> - functions which use GeoTools. e. g. st_transform,
> st_aswktsrs, st_geomfromkml
> - own functions. e. g. some linear referencing functions,
> M,Z coordinates in functions.
> - functions which have been ported from postgis. e. g.
> st_snaptogrid
> jaspa supports some postgis 1.5 functions: st_geomfromgml,
> st_geomfromkml, st_collectionextract,st_dumppoints.
> The geograpy type is not implemented (planned for next
> release) thats why we said postgis 1.4 compatibily and not
> postgis 1.5.
> > Hope that helps,
> > Regina and Leo
> > http://www.postgis.us
> Thanks Regina and Leo to write this email.
> Hope you guys can try jaspa when you have a while and give
> me some feedback.
> Anyways you have to think this is an academic project and
> the goal is not to be used in a production enviroment, at
> least by now. But
> it is a project which is easy to research on it, to extend
> new functionalities, to work with other databases or to be
> embedded in other
> java projects as well.
> Best,
> Jose
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net]
> On Behalf Of muhammad
> > imran
> > Sent: Friday, July 23, 2010 8:12 PM
> > To: PostGIS Users Discussion
> PostgreSQL and
> > Dear All,
> > What are the advantages of JASPA over PostGIS. If
> anyone can compare both
> > spatial extensions?
> > regards,
> > Imran
> > --- On Fri, 7/23/10, Jose C. Martinez-Llario <jomarlla at cgf.upv.es>
> wrote:
> >> From: Jose C. Martinez-Llario <jomarlla at cgf.upv.es>
> >> Subject: [postgis-users] JASPA (JAva SPATial) for
> PostgreSQL and H2
> >> Date: Friday, July 23, 2010, 6:33 PM
> >> (sorry for the cross posting)
> >> ************* text in english
> >> After one year of development, we are pleased to
> announce the release 0.1RC1 of JASPA (JAva SPAtial). JASPA
> potentially brings around 200 spatial functions to any
> relational database system that supports a full set of java
> store procedures. In this 0.1 version JASPA supports
> PostgreSQL and H2, and we are already working with HSQLDB.
> >> JASPA has a similar functionality as PostGIS 1.4,
> supporting spatial operators and predicates, arrays of
> geometries, spatial aggregates, etc. JASPA is written in
> java and is easy to extend using java store procedures.
> >> JASPA is licensed under the GNU GPL.
> >> This project has been possible thanks to other
> open source projects. Besides to take advantage of these
> projects we have used their mailing lists and they helped us
> a lot. The JASPA team is very grateful to them:
> >> - PostGIS. The mirror on which JASPA has been
> looking at.
> >> - JTS (Java Topology Suite). This library is
> widely used in JASPA and many open source initiatives
> bringing the possibility to use spatial analysis to the java
> open source world.
> >> - GeoTools (used for projections, KML support and
> Shape to JASPA converters)
> >> - PostgreSQL and PLJAVA (Java store procedures
> for
> >> PostgreSQL)
> >> - H2 and H2Spatial (a Java database and its
> spatial extension used at the beginning of JASPA)
> >> - HSQLDB (a Java database which probably will be
> supported by JASPA in the next release)
> >> - gvSIG (a desktop SIG which we hope it can
> connect to JASPA soon)
> >> The authors of this project are:
> >> Jose C. Martinez-Llario.
> Developer and project director. (1)
> >> Marta Gonzalez-Alcaide. Tester
> and document builder.
> >> (1)
> >> (1) Deparment of
> Cartographic
> >> Engineering, Geodesy and Photogrammetry at La
> Universidad Politecnica de Valencia (Spain).
> >> Any contributor is very welcomed
> to join the JASPA project.
> >> JASPA Download:
> >> - The latest software can be found at: http://forge.osor.eu/projects/jaspa/
> >> - The full JASPA documentation can be found at: http://jaspa.forge.osor.eu/. The online manual (the pdf
> version has more than 300 pages) includes the installation
> process from binaries and source, a tutorial and a complete
> reference of the JASPA commands.
> >> - Mailing list: http://lists.forge.osor.eu/mailman/listinfo/jaspa-users
> >> - JASPA is hosted on OSOR.EU at: http://www.osor.eu/projects/jaspa
> >> ************* text in spanish
> >> Tras un año de desarrollo, queremos presentaros
> la versión 0.1RC1 de JASPA (JAva SPAtial). JASPA
> potencialmente implementa alrededor de 200 funciones
> espaciales sobre cualquier base de datos relacional
> que soporte procedimientos almacenados en java. En esta
> primera versión JASPA soporta PostgreSQL y H2. Actualmente
> estamos trabajando para incorporar HSQLDB.
> >> JASPA tiene una funcionalidad muy similar a
> PostGIS 1.4, soportando predicados y operadores espaciales,
> arreglos de geometrías, agregados espaciales, etc. JASPA
> está programado en java y es bastante fácil de extender
> ampliando funcionalidades utilizando procedimientos
> almacenados en java. JASPA tiene una licencia GNU GPL.
> >> Este proyecto ha sido posible gracias a otros
> muchos proyectos de código abierto. Además de utilizar
> estos proyectos, sus correspondientes listas de correo nos
> han ayudado de forma rápida y eficaz. El equipo de JASPA
> quiere mostrar su gratitud especialmente a:
> >> - PostGIS. Es el espejo en el que JASPA se ha
> mirado.
> >> - JTS (Java Topology Suite). Biblioteca
> ampliamente utilizada en JASPA y muchos otros proyectos de
> código abierto, ofreciendo la posibilidad de realizar
> análisis espaciales.
> >> - GeoTools (biblioteca utilizada para las
> proyecciones y el soporte de KML y los importadores shape).
> >> - PostgreSQL and PLJAVA (implementa procedimientos
> almacenados en java para PostgreSQL)
> >> - H2 y H2Spatial (H2 es una base de datos especial
> desarrollada en Java, al inicio de JASPA H2 Spatial y
> Spatial Box ofrecieron ideas en la que se basó JASPA)
> >> - HSQLDB (base de datos java que posiblemente
> será soportada por JASPA en la próxima versión)
> >> - gvSIG (SIG de escritorio con el que realmente
> deseamos que JASPA se pueda conectar)
> >> Los autores de este proyecto son:
> >> (1)
> >> (1) Deparment of
> Cartographic
> >> Cualquier persona que quiera
> contribuir es bienvenida.
> >> JASPA Download:
> >> - Los binarios y el código fuente se puede
> encontrar en:
> >> - La documentación complete de JASPA en: http://jaspa.forge.osor.eu/. El manual en línea (la
> versión pdf tiene más de 300 páginas) incluye el proceso
> de instalación de forma detallada de los binarios y si se
> quiere compilar el fuente, un tutorial y una guía de
> referencia de todos los comandos de JASPA.
> >> - Lista de distribución (de momento sólo en
> inglés): http://lists.forge.osor.eu/mailman/listinfo/jaspa-users
> >> - JASPA está almacenado en OSOR.EU at: http://www.osor.eu/projects/jaspa
> >> postgis-users mailing list
> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
