[postgis-users] speeding up "not in" query
nguyen liem
liemnguyendl at gmail.com
Sun Jul 25 19:15:21 PDT 2010
Hi David,
you can use "except" instead of "not in", the query should be changed to:
SELECT survey.parcelnum
FROM survey
*except*
(SELECT parcel_esri.parcelnum
FROM parcels_esri)
I think the query above will be faster than the old one. After you had
survey.parcelnum, you can do something with these.
Cheers.
On Sun, Jul 25, 2010 at 4:09 AM, David Epstein <davideps at umich.edu> wrote:
> I have one spatial table and one non-spatial table each with about 380k
> rows. They can be joined by "parcelnum". However, there are some parcel
> numbers in each table that do not match. I want the full rows of the
> non-matching from each. I've made a standard (b-tree) index for
> "parcelnum" in both tables and then ran this query to get non-matching
> rows in a single direction:
> SELECT *
> FROM survey
> WHERE survey.parcelnum NOT IN
> FROM parcels_esri)
> This query has already run for 35 minutes and is still running. I have a
> laptop running Ubuntu 9.04 64bit with two P8700 2.53GHz CPUs and 3.8GB
> of memory. Only 1 CPU and 1.3GB of memory is being used. Is there
> anything I can do to speed up not-in (and join) queries?
> thank you,
> -david
> postgis-users mailing list
*Liem Nguyen (DBA)
AXON ACTIVE VIETNAM*
*www.axonactive.vn***
10th Floor, Hai Au Building, 39B Truong Son, Ward 4, Tan Binh District, Ho
Chi Minh City, Vietnam
T +84 8 629 738 59, F +84 8 381 134 89, M +84 168 994 8897
*8897 +10° 48' 32.72", +106° 39' 51.58"*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100726/432ad833/attachment.html>
