[postgis-users] Snapped polygon
nguyen liem
liemnguyendl at gmail.com
Tue Jul 27 01:06:34 PDT 2010
Hi Fabio,
I had a small test with your data. I split your data to 2 tables: blocks(big
polygon) and building(small polygon) table.
Please see the attached file for more details.
The environment is:
"PostgreSQL 8.3.5 on x86_64-unknown-linux-gnu, compiled by GCC gcc (GCC)
4.1.2 20070115 (prerelease) (SUSE Linux)"
I have some green comments bellow:
Cheers.
On Tue, Jul 20, 2010 at 9:59 PM, Fabio Renzo Panettieri <
fpanettieri at xoomcode.com> wrote:
> Hi.
> I'm, having a problem with some geometries.
> I have buildings and blocks represented by polygons, and I have to check
> if buildings are contained in blocks.
> The problem is that buildings that are snapped to blocks sides, aren't
> considered inside the block.
> These are the validations that I've used so far.
> ST_Covers(block, building) => false
ST_Covers(geometry geomA, geometry geomB); Returns 1 (TRUE) if no point
in Geometry B is outside Geometry A
> ST_Contains(block, building) => false
ST_Contains(geometry geomA, geometry geomB); Returns true if and only if
no points of B lie in the exterior of A, and at least one point of the
interior of B lies in the interior of A.
> ST_Coveredby(building, block) => false
ST_CoveredBy(geometry geomA, geometry geomB); Returns 1 (TRUE) if no
point in Geometry/Geography A is outside Geometry/Geography B
> ST_Within(building, block) => false
ST_Within(geometry A, geometry B); Returns true if the geometry A is
completely inside geometry B
> The following validations are the ones that confuses me.
> ST_Covers(ST_intersection(block, building), building) => true
=> false - plz see the explanation in the attached file
> ST_Intersection(block, building) = building => true
=> true: because "=" operator is a little more naive, it only tests
whether the bounding boxes of two geometries are the same
> ST_isEmpty(ST_Difference(building, block)) => true
> For what I've read, here
> http://lin-ear-th-inking.blogspot.com/2007/06/subtleties-of-ogc-covers-spatial.html
> "Geometry A covers Geometry B if no points of B lie in the exterior of
> A"
> Covers should return true.
> The environment is:
> SELECT version(); => "PostgreSQL 8.4.4 on x86_64-pc-linux-gnu, compiled
> by GCC gcc-4.3.real (Debian 4.3.2-1.1) 4.3.2, 64-bit"
> SELECT postgis_version(); => "1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> I've attached two geometries that you can use to check if I'm doing
> something wrong.
> Thanks for your time.
> Fabio R. Panettieri
> Software Architect
> http://www.xoomcode.com
> postgis-users mailing list
*Liem Nguyen (DBA)
AXON ACTIVE VIETNAM*
*www.axonactive.vn***
10th Floor, Hai Au Building, 39B Truong Son, Ward 4, Tan Binh District, Ho
Chi Minh City, Vietnam
T +84 8 629 738 59, F +84 8 381 134 89, M +84 168 994 8897
*8897 +10° 48' 32.72", +106° 39' 51.58"*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100727/4c3eb791/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100727/4c3eb791/attachment.obj>
