[postgis-users] Fwd: constraint violation : enforce_geotype_the_geom
Agustin Ignacio Genoves agustingenoves at gmail.com
Tue Jul 27 05:31:37 PDT 2010
You must check if the geometry is not null and the type is POLYGON
2010/7/27 Guillaume LONGUETAUD <mister.tefal at gmail.com>:
> Hello, there
> I'm quite new to postgis requests and I've got a constraint violation
> problem with one of my requests:
> create table bati_buff (id serial primary key);
> select addgeometrycolumn ('bati_buff', 'the_geom', 27572, 'POLYGON', 2 ) ;
> insert into bati_buff (the_geom)
> (select bati.the_geom from bati, buffer where intersects (bati.the_geom,
> buffer.the_geom) =true ) ;
> I have a constraint violation with the relation enforce_geotype_the_geom.
> How can I solve it ?
> Thanks
> Guillaume Longuetaud
> postgis-users mailing list
