[postgis-users] error in online PostGIS docs?
    Olivier Courtin
    olivier.courtin at oslandia.com
    Tue Jul 27 11:14:23 PDT 2010
On Jul 27, 2010, at 7:33 PM, Rick wrote:
Hi Rick,
> This refers to the documentation whose main page is : http://postgis.refractions.net/docs/index.html
> I've been experimenting with getting geometry in different formats.
> On this page: http://postgis.refractions.net/docs/ST_AsGeoJSON.html
> it is possible to get a dictionary like object that includes an
> object bounding box.  I like this.
> However I am not getting the results set out in the doc.  Unless I'm
> missing something, either the function is wrong, or the docs are
> wrong.
> We are discussing the fourth parameter in the call ST_AsGeoJSON()
> The documentation says that if 1 is set, a bbox is returned, it is
> not.  a bbox is included if 2 is set.  Other option values appear to
> have no effect.  (see docs)
The first ST_GeoJSON implementation came with 1.3.4
The four parameter option slightly changes since 1.4.0 (with bbox set
to 1)
as you mention if.
Do you refer to the right doc version ?
SELECT postgis_full_version();
To get PosTGIS version...
ST_AsGeoJSON doc from 1.3 branch
http://postgis.refractions.net/documentation/manual-1.3/ch06.html#id2577428
ST_AsGeoJSON doc from 1.4 branch
http://postgis.refractions.net/documentation/manual-1.4/ST_AsGeoJSON.html
HTH,
Olivier
