[postgis-users] Different results on different Platforms: PostGIS 1.5
Luís de Sousa
luis.a.de.sousa at gmail.com
Wed Jul 28 09:38:41 PDT 2010
Hi Ahmed,
Are we talking about the same CPU? Those differences are small enough to be
the result of different assembler code fed into different processors.
Personally, I wouldn't worry much about it. Rounding both results gets you
equal results.
Luís
On Wed, Jul 28, 2010 at 5:25 PM, Ahmed Shinwari <ahmed.shinwari at gmail.com>wrote:
> Hi All,
> I am using Postgres Plus 8.4 and the PostGIS 1.4 along with it. The problem
> is that I get different results on Windows XP & Linux-32 (Red Hat 5) from
> the same query.
> The SQL script is a bit lengthy so I have attached it with this email.
> Please run that SQL script file on psql terminal so that all of the
> pre-requisite Tables and Functions are created. At the end of this script
> there are two queries. I have pasted below the two queries and there results
> with respect to the two OS'.
> QUERY 1: SELECT area(the_geom) FROM buildings;
> -- Result on Windows XP
> area
> 205.548500000002
> (1 row)
> -- Result on Linux32 (Red Hat 5)
> area
> 205.5485
> (1 row)
> QUERY 2: SELECT length(geom) FROM roads;
> length
> 14.142135623731
> (1 row)
> length
> 14.1421356237309
> (1 row)
> The output from Query 1 is a bit bizarre. Instead of rounding and
> truncating it on Windows, '00000002' is appended to it. Is this normal? Or
> is it a bug. And also the output from Query 2 is different as well.
> Thanking in advance for any assistance.
> Regards,
> Ahmed
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100728/fb441e08/attachment.html>
