[postgis-users] converting to postgis
Birgit Laggner
birgit.laggner at vti.bund.de
Fri Apr 29 02:02:31 PDT 2011
Hi Farouk,
I always use a workaround in order to convert a shp file with special
characters in its attribute table into UTF-8 encoding: I open the shp
file's dbf in some calculation software (e.g. OpenOffice) and save it as
an csv with encoding UTF-8. Then I open the csv and save it again as a
dbf under a new name. Then, I exchange the old dbf by the new one (don't
forget to change the name to, so it does match the shp file name) and
the shp file gets imported into the postgis database without problems.
There are hopefully more elegant solutions, but for shp-import of only a
few files, it's ok...
Regards,
Birgit.
Am 29.04.2011 10:32, schrieb farouk azzouhri:
> Hello,
> I converted an Access database (contains two fields X and Y) in a .shp
> file it's ok, but when I wanted to convert the .shp into a postgis
> database ( using the shp2pgsql-gui.exe ) it gives me the following
> message:
> Unable to convert field name to UTF-8 (iconv reports "Illegal byte
> sequence"). Current encoding is "UTF-8". Try "latin1 " (Western
> European), One Of The gold values at
> http://www.postgresql.org/docs/current/static/multibyte.html Described.
> Shapefile import failed.
> how I'm going to do ??
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110429/be62450f/attachment.html>
