[postgis-users] Persist PostGIS Layers in ArcMap Document and LayerFiles (UNCLASSIFIED)
Brundage, Robert G Mr CIV USA IMCOM
robert.g.brundage at us.army.mil
Wed Aug 24 12:53:48 PDT 2011
Classification: UNCLASSIFIED
Caveats: FOUO
Thanks for the notification. I have downloaded the corrected version.
Bob Brundage
IGI&S Manager
Public Works (DPW) Bldg 852
Fort Campbell, KY 42223
Phone: 270-798-9571
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Kenneth Xu
Sent: Wednesday, August 24, 2011 2:29 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Persist PostGIS Layers in ArcMap Document and
LayerFiles
Due to an incident, a small component was lost while compiling PgMap
2.2. This makes the ArcMap map document files and layer files created by
PgMap 2.2 were not able to be persisted with PostGIS layer information.
We have corrected this and a new PgMap 2.2 download package is now
available on WWW.ST-Links.com. If you ever installed PgMap 2.2, please
download this new parckage and install it again.
PgMap 1.0, PgMap 2.0 do not have this problem.
-Ken Xu
www.st-links.com
==== Answers to the following questions.
Hello,
Thanks for sending the registration file across, I've been testing the
application with some PostgreSQL tables and have come across a couple of
problems which I hope you might be able to help with.
1) The data sources do not persist between sessions so when I restart
ArcMap none of the layers I saved have the correct source and are
showing exclamation marks. I get a message that the extension is not
enabled even though it is checked from the Extensions menu. I have to
uncheck it and check it again to enable it. Even with this working if I
close the MXD and re-open it the sources are still not correct and I
have to manually set all of the layers to the correct table again.
2) I can't get the edit features functionality to work. I've setup a
serial column and added a unique constraint to it too but it still isn't
working.
They get placed on the map but as soon as you save edits they disappear.
Looking at attributes of existing features I can see the attributes but
they are all greyed out and I can't edit them.
Thanks for your help,
Peter.
Application Support Analyst
Middleware Technologies Team
Service Birmingham
Kenneh Xu
GIS Consultant
www.st-links.com <blockedhttp://www.st-links.com/>
kenneth.xu at hotmail.com
Caveats: FOUO
