[postgis-users] Retrieve a feature having point coordinates
Alessandro Candini
candini at meeo.it
Tue Dec 27 02:44:16 PST 2011
It seems very complicated for what I need...no other ways to do:
" give me the feature ID which contains this point"?!
I was trying using something like:
SELECT gid,the_geom FROM salzburg WHERE ST_Contains(the_geom,
ST_PointFromText('POINT(47.7 13.01)', 900913));
but the result is 0 rows.
Is this approach correct?
> Yap, as i said it only works for points. If you have lines or polygons
> you may build the bounding box of them and try it with st_xmin etc.
> It did it this way:
> SELECT id,tags,linestring
> FROM ( SELECT id,tags,linestring,(each(tags)).key AS key FROM ways ) sub
> WHERE st_xmin(st_box2d(linestring)) >=9.362383 AND
> st_xmax(st_box2d(linestring)) <=9.417143
> AND st_ymin(st_box2d(linestring)) >= 51.478924 AND
> st_ymax(st_box2d(linestring)) <=51.511413;
> 2011/12/27 Alessandro Candini <candini at meeo.it <mailto:candini at meeo.it>>
> It dosn't work sayng to me the following:
> ERROR: Argument to X() must be a point
>> Maybe you want to try it this way:
>> SELECT gid,geom FROM mytable
>> WHERE st_x(geom) >=45.19 AND st_x(geom) <=45.21
>> AND st_y(geom) >=23.29 AND st_y(geom) <=23.31
>> It finds all points in the given bounding box. But you cannot
>> specify exactly one point, because there could be more than one
>> at this point.
>> Hope that helps although.
>> Cheers.
>> Hi list.
>> I'm new to Postgis world and I have a probable dumb question:
>> I have a shape file inserted into a postgis database through
>> shp2pgsql utility and I would like to retrieve a feature ID
>> giving as input a pair of lat/lon coordinates.
>> Something like "SELECT gid from mytable WHERE
>> point_is_into(45.2, 23.3);"
>> How can I achieve this?
>> Thanks in advance.
>> Alessandro Candini
>> MEEO S.r.l.
>> Via Saragat 9
>> I-44122 Ferrara, Italy
>> Tel: +39 0532 1861501 <tel:%2B39%200532%201861501>
>> Fax: +39 0532 1861637 <tel:%2B39%200532%201861637>
>> http://www.meeo.it
>> "ATTENZIONE:le informazioni contenute in questo messaggio sono
>> da considerarsi confidenziali ed il loro utilizzo è riservato
>> unicamente
>> al destinatario sopra indicato. Chi dovesse ricevere questo
>> messaggio
>> per errore è tenuto ad informare il mittente ed a rimuoverlo
>> definitivamente da ogni supporto elettronico o cartaceo."
>> "WARNING:This message contains confidential and/or proprietary
>> information which may be subject to privilege or immunity and
>> which
>> is intended for use of its addressee only. Should you receive
>> this
>> message in error, you are kindly requested to inform the
>> sender and
>> to definitively remove it from any paper or electronic format."
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
> Alessandro Candini
> MEEO S.r.l.
> Via Saragat 9
> Tel:+39 0532 1861501 <tel:%2B39%200532%201861501>
> Fax:+39 0532 1861637 <tel:%2B39%200532%201861637>
> http://www.meeo.it
> da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
> al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
> information which may be subject to privilege or immunity and which
> is intended for use of its addressee only. Should you receive this
> message in error, you are kindly requested to inform the sender and
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
http://www.meeo.it
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111227/20a69dbb/attachment.html>
