[postgis-users] Retrieve a feature having point coordinates
Michel Seuthe
m.seuthe at googlemail.com
Tue Dec 27 03:01:09 PST 2011
Okay, how ST_Equals? Like:
SELECT gid,the_geom FROM salzburg WHERE ST_Equals(the_geom,
ST_PointFromText('POINT(47.7 13.01)', 900913));
I haven't tried, just an idea.
And make sure that the SRID of your point also is 900913.
2011/12/27 Alessandro Candini <candini at meeo.it>
> It seems very complicated for what I need...no other ways to do:
> " give me the feature ID which contains this point"?!
> I was trying using something like:
> SELECT gid,the_geom FROM salzburg WHERE ST_Contains(the_geom,
> but the result is 0 rows.
> Is this approach correct?
> Yap, as i said it only works for points. If you have lines or polygons you
> may build the bounding box of them and try it with st_xmin etc.
> It did it this way:
> SELECT id,tags,linestring
> FROM ( SELECT id,tags,linestring,(each(tags)).key AS key FROM ways ) sub
> WHERE st_xmin(st_box2d(linestring)) >=9.362383 AND
> st_xmax(st_box2d(linestring)) <=9.417143
> AND st_ymin(st_box2d(linestring)) >= 51.478924 AND
> st_ymax(st_box2d(linestring)) <=51.511413;
>> It dosn't work sayng to me the following:
>> ERROR: Argument to X() must be a point
>> Maybe you want to try it this way:
>> SELECT gid,geom FROM mytable
>> WHERE st_x(geom) >=45.19 AND st_x(geom) <=45.21
>> AND st_y(geom) >=23.29 AND st_y(geom) <=23.31
>> It finds all points in the given bounding box. But you cannot specify
>> exactly one point, because there could be more than one at this point.
>> Hope that helps although.
>> Cheers.
>>> Hi list.
>>> I'm new to Postgis world and I have a probable dumb question:
>>> I have a shape file inserted into a postgis database through shp2pgsql
>>> utility and I would like to retrieve a feature ID giving as input a pair of
>>> lat/lon coordinates.
>>> Something like "SELECT gid from mytable WHERE point_is_into(45.2, 23.3);"
>>> How can I achieve this?
>>> Thanks in advance.
>>> Alessandro Candini
>>> MEEO S.r.l.
>>> Via Saragat 9
>>> I-44122 Ferrara, Italy
>>> Tel: +39 0532 1861501 <%2B39%200532%201861501>
>>> Fax: +39 0532 1861637 <%2B39%200532%201861637>
>>> http://www.meeo.it
>>> "ATTENZIONE:le informazioni contenute in questo messaggio sono
>>> da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
>>> al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
>>> per errore è tenuto ad informare il mittente ed a rimuoverlo
>>> definitivamente da ogni supporto elettronico o cartaceo."
>>> "WARNING:This message contains confidential and/or proprietary
>>> information which may be subject to privilege or immunity and which
>>> is intended for use of its addressee only. Should you receive this
>>> message in error, you are kindly requested to inform the sender and
>>> to definitively remove it from any paper or electronic format."
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
>> Alessandro Candini
>> MEEO S.r.l.
>> Via Saragat 9
>> Fax: +39 0532 1861637http://www.meeo.it
> Alessandro Candini
> MEEO S.r.l.
> Via Saragat 9
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111227/af0c9f9b/attachment.html>
