[postgis-users] Retrieve a feature having point coordinates
Alessandro Candini
candini at meeo.it
Tue Dec 27 03:14:03 PST 2011
I get it! The following query works:
SELECT gid FROM salzburg WHERE ST_Contains(the_geom,
ST_PointFromText('POINT(1451405.4004687 6071678.9812547)', 900913));
The problem was that point coordinates must be in meters (because of the
google projection) and not in lat/lon values.
Thank you so much for your help!
> Okay, how ST_Equals? Like:
> SELECT gid,the_geom FROM salzburg WHERE ST_Equals(the_geom,
> ST_PointFromText('POINT(47.7 13.01)', 900913));
> I haven't tried, just an idea.
> And make sure that the SRID of your point also is 900913.
> 2011/12/27 Alessandro Candini <candini at meeo.it <mailto:candini at meeo.it>>
> It seems very complicated for what I need...no other ways to do:
> " give me the feature ID which contains this point"?!
> I was trying using something like:
> SELECT gid,the_geom FROM salzburg WHERE ST_Contains(the_geom,
> but the result is 0 rows.
> Is this approach correct?
>> Yap, as i said it only works for points. If you have lines or
>> polygons you may build the bounding box of them and try it with
>> st_xmin etc.
>> It did it this way:
>> SELECT id,tags,linestring
>> FROM ( SELECT id,tags,linestring,(each(tags)).key AS key FROM
>> ways ) sub
>> WHERE st_xmin(st_box2d(linestring)) >=9.362383 AND
>> st_xmax(st_box2d(linestring)) <=9.417143
>> AND st_ymin(st_box2d(linestring)) >= 51.478924 AND
>> st_ymax(st_box2d(linestring)) <=51.511413;
>> It dosn't work sayng to me the following:
>> ERROR: Argument to X() must be a point
>>> Maybe you want to try it this way:
>>> SELECT gid,geom FROM mytable
>>> WHERE st_x(geom) >=45.19 AND st_x(geom) <=45.21
>>> AND st_y(geom) >=23.29 AND st_y(geom) <=23.31
>>> It finds all points in the given bounding box. But you
>>> cannot specify exactly one point, because there could be
>>> more than one at this point.
>>> Hope that helps although.
>>> Cheers.
>>> Hi list.
>>> I'm new to Postgis world and I have a probable dumb
>>> question:
>>> I have a shape file inserted into a postgis database
>>> through shp2pgsql utility and I would like to retrieve a
>>> feature ID giving as input a pair of lat/lon coordinates.
>>> Something like "SELECT gid from mytable WHERE
>>> point_is_into(45.2, 23.3);"
>>> How can I achieve this?
>>> Thanks in advance.
>>> Alessandro Candini
>>> MEEO S.r.l.
>>> Via Saragat 9
>>> I-44122 Ferrara, Italy
>>> Tel: +39 0532 1861501 <tel:%2B39%200532%201861501>
>>> Fax: +39 0532 1861637 <tel:%2B39%200532%201861637>
>>> http://www.meeo.it
>>> "ATTENZIONE:le informazioni contenute in questo
>>> messaggio sono
>>> da considerarsi confidenziali ed il loro utilizzo è
>>> riservato unicamente
>>> al destinatario sopra indicato. Chi dovesse ricevere
>>> questo messaggio
>>> per errore è tenuto ad informare il mittente ed a rimuoverlo
>>> definitivamente da ogni supporto elettronico o cartaceo."
>>> "WARNING:This message contains confidential and/or
>>> proprietary
>>> information which may be subject to privilege or
>>> immunity and which
>>> is intended for use of its addressee only. Should you
>>> receive this
>>> message in error, you are kindly requested to inform the
>>> sender and
>>> to definitively remove it from any paper or electronic
>>> format."
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> <mailto:postgis-users at postgis.refractions.net>
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
>> Alessandro Candini
>> MEEO S.r.l.
>> Via Saragat 9
>> Tel:+39 0532 1861501 <tel:%2B39%200532%201861501>
>> Fax:+39 0532 1861637 <tel:%2B39%200532%201861637>
>> http://www.meeo.it
>> "ATTENZIONE:le informazioni contenute in questo messaggio sono
>> da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
>> al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
>> "WARNING:This message contains confidential and/or proprietary
>> information which may be subject to privilege or immunity and which
>> is intended for use of its addressee only. Should you receive this
>> message in error, you are kindly requested to inform the sender and
>> to definitively remove it from any paper or electronic format."
> Alessandro Candini
> MEEO S.r.l.
> Via Saragat 9
> http://www.meeo.it
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
http://www.meeo.it
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20111227/2fdc0fb1/attachment.html>
